Strictly the 4x4 lowering thread...
ryan russell
Springdale Pa
I didn't use Durango bags on mine I used a measurement method to order mine from the sized ones they got. And bags won't really lift the rear when aired up. They stiffen the ride for hauling. I run 5 lbs in mine at all times. If I run 10-15 without a load it's super harsh
Midnight Storm
One Badass Ram
Victoria, B.C Canada
Do you happen to have the model number, as we all seem to have the same kit?
dracman
canada
2017 black out edition
how low can we go in the front of these 4x4. and how does everyone truck ride like with the 2/4
If you actually use it as a 4X4 ,I wouldn't go much lower then 2" ,otherwise you'll be replacing CV's more often then you like.Plus if you drop much lower then 2" the CV's run in a constant bind situation and will cut into your gas milege.You can go to 4" with the Inez kit,or by using dropped spindles and a 2" drop strut,but I wouldn't do either if you want your CV's to last.My 4X4 is dropped 2" on the front using drop spindles,the 2X4 drop spindles will fit on a 4X4
BrBlack
Calgary Alberta
I've got the GF kit. 2" drop springs upfront and a set of OEM 2wd spindles. So aprox 3" down in front. No binding on the CV's. Rides great with a set of bilstiens in there. No stock ride quality but good enough for me.
I've got about 20,000km on this setup now.
A local guy to me did 2" springs and 2" drop spindles and said the binding on CV's starts around 4" lower in the front. I wasn't getting into that mess so choose the OE 2wd spindles.
H1Chester
Anyone else have the belltech 965sp kit and want to show a pic or tell about your joys or sorrows?
View media item 27890View media item 27942View media item 27895View media item 27898
I put the SRT replicas on a couple of weeks prior to the drop. I don't know if it is the setup or the wheels and tires but I have a flutter bounce feeling from 55mph - 70mph range. The wheels and tires have been balanced multiple times and I think its a bad set of Nittos. I have to go back to get them looked at one more time then filing a warranty claim with the vendor where I bought them from. From all the posts I've read about Belltech, it should not be doing this.
I also have somewhat of an install thread if you search for it. Its more of a post of all the problems I had during the install.
Midnight Storm
One Badass Ram
I didn’t mean you silly. I already know all about yours!
Dobaramguy84
Tonwanda, n.y
Did anyone use the spring insulators out of the 91213 groundforce kit or stick with the stock ones? Just curious
tones2SS
MA
I think tht's the kit I used?
Is that the GF 2" rear drop kit with springs/shocks?? It looks familiar.
Dobaramguy84
Tonwanda, n.y
I just said the he'll with it and put the full rear drop kit in from groundforce. I dig it. Still considering the mcg's drop spindles for the front.
