@BOWERSFJ I'm looking for something that does not have spacers.
Thank you for the info
@kurek &
@ram1500rsm. Certainly worth considering. From the Mopar one uses spacers as well and again, I'm not into that. I've also heard that the Mopar kit is more of an appearance package compared to the stuff from Fox, ICON and Kings.
From what I have been told most suspension kits focus on off-roading and reduce the payload over stock.
I'm mostly looking for a 3" lift kit (without spacers) that will retain the stock payload capacity and towing of my SLT. Increasing would be preferable than reducing it.
So far ICON is the only one that I have heard of that will retain the stock payload while giving the truck a lift. But Will the Icon Stage 5 give me the 3" inch lift?
I've heard about the King shocks and quite a few people swear by them. I don't know if they have a kit the similar to the ICON Stage 5.
That's because King is King
Joking asides, what makes the Icon stage 5 kit ?
http://iconvehicledynamics.com/shop...dodge-ram-1500-suspension-system-stage-5.html
Icon 1.5" rear springs, part# 212150
Icon Delta Join UCAs: part# 218550DJ
and 2.5 CO's front 2.5 piggybacks rear shocks with RES and CDC. Keep in mind the Icon front CO's for the RAM 1500 application don't include reservoirs nor a CDC option. They say is because they don't have space to allocate a hose and the RES. I think it's a mistake they're making not adding those as their competition does and nobody seems to have any issues running them, heck i run my Kings with 37's pretty much like that dude in the video you posted with the Icon setup (that truck has been an inspiration for my build) and i have yet to rub the RES with those big tires
I think Icon make good kits, i had their Toyota Taco stage 5 before and they have a lot more options in that application for sure but they don't offer RES and CDC front for the CO's in the RAM so this time i didn't look at them and went straight with Kings.
King, Fox and Radflo OE kits don't include UCA's or the rear springs like Icon do, just the 2.5 Coilovers for the front and the 2.5 rear shocks, but they all give you a reservoir for both their CO's and rear piggyback shocks, and you have the option to choose CDC or not.
all you have to do is add your choice of UCA and rear springs.
For Rear springs you have:
Icon 1.5" part# 212150
Bilstein 1" part# 36-286539
Mopar 2" (Superlift make this springs, part# SLF-140)
Eibach 1" , part# E30-27-001-02-02
Carli 0.5" , part# CS-RAM15MRC-14-R
There are more coil springs in the 1" category but they're shorter than stock, designed more for work than fun, shorter springs with longer shocks don't mix well...
I tried the SLF-140 springs as i was looking for more offroad performance. if you're setting the truck for offroading they are really long, so you can get 29-30" rear extended shocks which is awesome for more rear suspension travel. I was looking to replace my 27" extended King rear shocks with 29" ones and those coil springs came handy but after installing them i found out they're not exactly a coil spring you want for overlanding (my truck is setup with a little more of that in mind) They sagged their full 2" in a matter of 3 days for me so i returned them very quickly.
Plus when you see people racing their chit and posting this, you don't want to have the same ocurrence... check post # 11 here.
https://www.ramforum.com/threads/upgrading-from-bilstein-to-fox.132275/
So what can you have asides from Icon kit?
Kings:
http://www.kingshocks.com/products/oem/ram-trucks/
If you want custom valving, you can get them from Filthy motorsports, just tell them what mods do you have in the truck and how much abuse you're going to give it and they will fill in the blanks for you. Keep in mind they also offer even more performance if you want to use shocks with internal bypasses (IBP's) or external bypasses. Sky is the limit here.
https://www.filthymotorsports.com/King_OEM_RAM_1500_Shocks_p/king-25001-207.htm
Same with Accutune, and they offer Kings and Fox with custom valving. they also have IBP's, bypasses ect etc.
https://accutuneoffroad.com/product...ucts/dodge/ram-1500/dodge-ram-1500-2016-2009/
Thuren makes custom valving for the RAM 1500 using Kings as well
https://www.thurenfabrication.com/p...suspension-systems/thuren-ram-1500-kings.html
And Carli makes a more complete kit with Kings, UCA's and rear springs, but their rear springs are supposed to be just 1/2" higher than stock.
https://carlisuspension.com/product...stems/dodge-1500-performance-2-5-system-2009/
Fox
https://www.ridefox.com/subhome.php?m=truck&make=Ram&model=1500+&year=2014&position=ALL
Radflo
https://www.radflo.com/c-47-jeep-truck-suv-shocks-shocks-by-make-dodge-ram.html
All of them can make you IBP's and external bypasses, i'm just listing what they offer off the shelve for the RAM 1500.
All these kits do use front coilovers and they're good for 2-3" lift, just crank them up and up she'll go, follow the manufacturer recommendation on how much preload you can add before you added too many turns into your coilovers to go up, and don't exceed 3", i'm setup for 2.75" and still have room to go higher, you'll get better performance at 2.5" though because the CO's will have more travel up/down, but you can definetely go higher. They should all be extended travel (1" more extension than stock) or at least i can vouch for the King CO OE setup being extended travel.
You can get the UCA's from Icon or any other vendor you like, Zone, ReadyLift, JBA, CST, Total Chaos, Maxtrac, BDS, etc etc. You have different BJ styles and bushings to choose from, Uniballs are best for offroad/racing performance as they can take more abuse, but the standard BJ (like Zone) do last longer with zero maintenance, just less pivoting performance. Icon Delta joins and JBA have both nice joints, Icon have poly bushings which can be a little noisy if you don't keep adding grease to them. JBA's use elastomer bushings better than poly in the noise deparment and i think no maintenance. Zone have standard rubber bushings, they last long and requiere no maintenance but the bushing tend to flex like a mother facker offroad, poly or heims will keep things where they need to be with less flex or no flex, more noise though but what the heck i'm not driving a little princess here hahaha. Never had the JBA version so i can't tell you if that bushing will flex like standard rubber or not but they're noise free and in theory require no maintenance? i'm just waiting for my Zone UCA's BJ to say goodbye before i'll replace them with something different, that might take a good while but i'm not in a rush.
If you're setting the truck for max bashing/race, then you have UCA uniballs with heims, and long travel complete kits, noise will be through the roof but when you're setting things up for max bashing/racing, noise is not a concern and it's understood you'll have plenty of it to enjoy
, IBP's will be quiet as stock, external bypasses will click like mfackers.
Dirt King
https://dirtkingfabrication.com/collections/ram and
Gor Racing,
https://gorracing.com/t/race
all 3" of native pure suspension beef.
Enjoy whatever kit you go with, and post some pics and impressions once you're done. We love pics around here hahaha.
