It's official then we can recommend oils with over 200ppm moly as a possible answer to hemi tick with Corey's (H395) success. I remember how nervous he was switching after his failures, so kudo's for trying it over Redline. I would however caution people running the average amount of moly (60ppm) and thinking that is an answer for tick, that simply hasn't been the case. And with all of the Cam and Lifter failures and guys not running moly oils I would say you would have to be crazy not to have some moly even if you don't have the tick.
Another option we haven't really been talking about is running a couple qrts of Redline with your mix for a moly boost. Especially for folks not wanting to run a 40 weight in their mix. It isn't as neat as running the same oils like some PP and some PUP, but you only need a qrt or two to any oil and it will boost moly twice as much as anything out there except motul.
