Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
For the (Elderly-Senior Citizen) crowd: Pennzoil Created a Very Robust Re-Energizing Sunshine Yellow!
Notice the HM...
Loaded with Testosterone & ****** with just a pinch of HGH!
This is not just your everyday Voooo Doooo! This is a special blend of Voooo Doooo... Use with extreme caution! It causes a few items to Swell which prevents leakage!
Amazing Brilliant Colors --->Don't you think?
Not to mention the Totally Re-Engineered Gulp Free 5Qt Jug!
16 Finely Tuned Engineers from the Voooo Doooo Accademy worked many years perfecting this design. Isn't she a Beaut!
Molded Perfectly for the Smallest (Sensitive) hands to the largest rough & callused hands.
R.L.K.
Bristol , Tn.
Well ya Know ...
Sent from my SM-G900V using Tapatalk
Reactions: U&A
Skubasteve!
So I just got my lubegard in the mail, am I OK to add this entire 15oz bottle to my already 7qts of oil?! Will it overfill or anything? Thanks
Burla
2010 Hemi Reg Cab 4x4
As long as you are not over the fill line when you dump it, you should be fine. 15 ounces over full line is a ok. Dump it in. Do you have tick?
Skubasteve!
Thanks Burla. I have a m1 5w20 and m1 filter with about 800 miles or so in there. I have the random 4 second staetup tick. I will report any noticeable differences.
R.L.K.
Bristol , Tn.
Going on a 500 mile trip on Friday with the family. Good opportunity for the voodoo juice moly to plate[emoji16]
In less than two weeks I'll be changing the oil on the wife's 16 Challenger (5.7L ) 2nd run of Redline .
Last time it.was 50/50 RL 20wt & RL.30wt .
No tick or any loud noise .. quite & very much smooth so far ....only 8-9 k total miles ( I think )
This time I'll be pouring in another 50 / 50 mix of REDLINE 20 &30 wt
Then we are off to Panama city for 3 nights , then 5 nights @ Disney World , then 4 nights @ Universal Studios and finally two nights at Fall Creek Falls St . Park in Tennessee (tallest waterfall east of the Mississippi )
Plenty of miles to continue the plating of Molybdenum & zinc with the added phosphorus in the mix .
U&A
2016 3500 SRW
6.4 HEMI
Just orderd a 12 quart case of Redline 0w40 on Amazon Prime. Came out to $11.50 a quart before tax.
Not bad. Best i saw for that weight in a few weeks. But a few months ago it was about $10.60 before tax.
Burla
Avatar wednesday
U&A
2016 3500 SRW
6.4 HEMI
What was the RP filter # that is slightly larger than the stock one?
R.L.K.
Bristol , Tn.
I just received a Gal jug of REDLINE 5W-20 tonight for the wife's 16 Challenger oil change of 50 / 50 20 & 30 wt Redline oil.
R.L.K.
Bristol , Tn.
Its works on the 5.7?
Yes sir , it's a larger version of the RP 10-48 filter .
It was the filter P/N for the 2012 & older trucks with the 5.7L
But it fits and works on the 2013 + RAM'S with the 5.7L as well .
U&A
2016 3500 SRW
6.4 HEMI
RP 20 -820
as fare as we know, how many are using it with success? and how similar is the by-pass valve settings ( PSI) and the flow rate (GPM) to the one that is recommended for the 5.7?
EDIT: never-mind, post #9657 answered my question....in a way. thanks
R.L.K.
Bristol , Tn.
Hemi395 is using it , and I have 2ea in my shop that I plan on using on my next oci .
Not sure on the bypass psi ; however, the 2012 5.7L ( engine wise / oil wise ) is very similar to the 13 +
Orca
