- May 11, 2016
- 219
- 338
- Location
- North Carolina
- 2017
- 5.7 Hemi
So you are not surprised, should you order the Perma Cool filter relocation kit for the stock filter, the M22 x 1.5 nipple used is machined from 1/2" ID thick walled steel tubing. One end is threaded for M22 x 1.5, and the other is turned down a bit, and threaded for 3/4-16. Perma Cool used this approach because the remote filter mount itself is threaded to accept a 3/4-16 nipple.
The base diameter is machined wide enough such that any stock (M22) filter can be used and seals perfectly, but if you replace the combination nipple with a straight 3/4-16 nipple, any standard filter threaded for that opening will also seal perfectly.
