- May 8, 2017
- 3,029
- 3,880
- 2017
- Hemi 5.7
Before I'd use 0 wt I'd move to warmer climate.
Sent from my XT1650 using Tapatalk
After seeing Pennzoils website recommendations, I'm assuming the dealers 0w20 is either PP or P Gold. My wife's Grand Cherokee 3.6 rattled like crazy on cold starts with what the dealer put in. The FF wasn't nearly as noisy as what the dealer put in.I know my wife's GC didn't like the 0/20 that the dealer put in it. Noisey as hell and ran like crap.
I'm really starting to think it may not be the valve train that's causing ticking. Wouldn't a cam that's getting smoothed by a seized roller be essentially silent? There's constant pressure on the pushrod and therefore the lifter from the valve spring so there shouldn't be any broken contact between the cam lobe and the lifter. Been thinking about this with all the cam failures lately, thoughts?
Exactly what I was thinking. If I had to call the hemi tick noise something on a SBC, it would be excessive valve lash. But if that were the case, why would Redline quiet it?I completely understand what you are saying. I have thought this befor and cant seem to make 100% sense for the true hemi tic. It is such a loud tic when you have tru hemi tic that its hard to believe.
But these engines are so simple that there is not much else going on up their. It has to be just one of them on each engine that is ticing. The pattern of the sound is to far apart to be more than one of them. Otherwise it would sound like a full auto AK if it was a handfull if them all at once.
But im not a mechanic. So im just guessing what is happening based on how i know these things oporate.
That would be my concern with a smoothed cam lobe as well. All those metal shavings would have to go somewhere. BUT I think the critical thing is how big are the shavings? If it's gradually smoothing the lobe over time it's most likely getting caught by the filter and washed out every oil change. IMO a good reason to get a filter magnet.I saw some posts that say that truck needed motor replacement because the cam was worn and there were metal shavings through.
What are the chances of that happening? I'm worried that instead of a regular cam and lifters job which could cost $4k, I'll need a whole new motor which will be 10k or so...
Ha ha , because Redline oil is liquid gold [emoji44][emoji44][emoji44]
