- Apr 28, 2012
- 23,283
- 45,022
- 2010 Hemi Reg Cab 4x4
- Hemi
@ CunningStunt ,
I can't believe no one has responded to your post , so I'll try to answer your questions ....but first I have a question for you Sir ...
You said you've had 4ea oil changes and you are approching 100,000 miles ...??
Did you purchase this truck new or used ?
If new ....what oil have you been using with such HIGH oil change intervals ???
If used , how many miles on the engine when you purchased ?
NowI'll try to answer your questions ...[emoji16]
First off a ticking noise is NOT normal unless you are hearing the fuel injectors ...you may be hearing an exhaust leak ??? Many here and abroad have had broken exhaust manifold bolts ...
IMHO ....you should not be using a 20wt oil in your hemi 5.7L 395 HP Engine , a 20wt oil is for a 4cylinder engine ....the 20 wt oil is an ignorant government fuel saving standard impossed on vehicle manufacturers ( has nothing to do with protection for your engine )
I'm the guy who is running a 50/50 mix of Redline 10W & 5W DASH - 30 OIL ....this is for higher Molybdenum , Zinc and Phophorus ppms in these two oils , and the 10W I believe has the higher Molybdenum, zinc & phophorus.... I'll be doing a UOA aka Used Oil Analysis soon to verify these claims I've read on the 10W Redline .
I and many others believe the higher ppm s of Molybdenum , phophorus and zinc is the best mixture for the 5.7L hemi ....modern oil regulations ( cafe ) have lower phophorus & zinc )
As for the type of RP Filter we are using :::
RP 10-48
Or
RP 20-820
The 20-820 is the larger of the two and fits just fine on the 2013 - 2018 Ram trucks .
Hope this helps !!
Cold start noise, with Pennzoil and castrol would get lifter noise like dry starts. That was gone with Amsoil but sounded like it rockers were running dry for a couple of seconds till oil got pumped up there. At the present time with M1 no noises.Ramnewbie: What do you really mean by saying Better?
Better @ what?
Chris: You are 100% correct on your assumption.
I myself used 6Qts of the SRT 0W-40 & 1qts of 5W-30 year round & my 5.7L reacted extremely well to this combo. No issues & averaged 19.6 mpg.
Amazon is always in stock with the SRT 0W-40. The last case I bought w/Prime was $54!
The SRT version is on the thin side & will shear down within the range of a thick 30wt within a couple thousand miles.
Shell possibly still uses the Tri-Nuclear Moly within this Oil (Very High Quality Moly) which makes this Oil a proven top performer at any level.
Switch to RL if you like—->I for see zero issues with either.
You can go to Redline's website and use their find a suppliers function ....there are very few ...what auto store carries redline oils?
I know redlines website used to say that advance auto parts had it, it still may, but the only redline product we had in the store was water wetter, and we don't even carry that anymore. We can get redline but it's not in the store and quiet frankly it wasn't a great price. Even with my employee discount I could do just as good ordering straight from Redline, and I know there's better deals than that.You can go to Redline's website and use their find a suppliers function ....there are very few ...
Imo it's best to get it from Nick@GotExhaust a member and vendor here on the forum . Nick's prices are Fantastic and his Shipping is free [emoji6]
