- May 8, 2017
- 3,029
- 3,880
- 2017
- Hemi 5.7
Everybody together now. BSI wanted to post this for the readers. Enjoy! Have a slippery weekend LOL
Oil Viscosity is an important decision when choosing your oil, regardless of oil brand. Because all engines are constructed with “very specific” clearances between internal engine components. Those clearances are determined by the engine designers (engineers) and that’s why they give you the recommended oil weight. So why is this important? It’s because internal engine components are cooled by oil “Directly” and cooled by the coolant “Indirectly”. So running a thicker oil than what is recommended is a bad idea in most cases. Because oil “flow” through internal engine clearances is critical for proper lubrication and to pull heat from internal engine components. The engine oil temperature in these areas of the engine can be 50-90 degrees “Hotter” than oil sump temperatures; thinner oils flow better than thicker oils pulling more heat from internal engine components. I tested this by switching from manufacturer recommended 5w20 to 5w30 while canyon racing in the North Georgia mountains, and my oil sump temperatures were 16 degrees “Hotter” on average running the thicker oil. Why? Because the thicker oil’s flow “slower” through internal engine components and get hotter, driving up bearing temperatures, reach or exceed the oils thermal stability (more on that below), lubricate less affectively and pull less heat from your engine. Thicker oils do provide options with mechanical noise, but mechanical noise doesn’t necessarily mean there is a problem with the engine; usually just annoys the vehicle owner. Bottom line, choose your oil viscosity specific to your needs. But if you choose a thicker oil, you need to understand what is happening inside your engine.
Now that you understand the importance of oil viscosity let’s talk about the single “Most” important aspect of oil. Anti-wear performance! Your oils anti-wear performance is the most critical job of your oil of choice, and differs wildly between different brands of oil. Doesn’t matter what oil manufactures you choose they “All” say their oil is the best. So where does that leave us? Where do we go to see the difference between oil and how they perform against one another? You, I, most of us end up on the internet forums getting opinions from “Self-Proclaimed” oil experts. They talk about base oil, oil additives, post used oil analysis (UOA) and ****** oil analysis (VOA). Trying to helplessly prove that their oil of choice is better. Or prove some other pathetic point that has no relevance on the oils anti-wear performance. So where does that leave us? Were right back to the first and most important issue with oil choice, How Does It Perform against other oils???? There is only one (1) place you can this information, and the link to the oil testing site is in my signature, and at the end of this post. 216 oils tested and compared by a qualified mechanical engineer, independent, controlled, repeatable oil testing that you Cannot find anywhere else. Your only other option is to listen to some self-proclaimed oil expert pretending to be something they could never be.
Now that that you can freely scroll through the oil testing site and see how oils compare against one another, and you understand the importance of oil viscosity. Let’s talk about the next important aspect of oil. Thermal Stability! Oil thermal stability is the oils ability to maintain anti-wear characteristics while heated past design. All oils have a drop in anti-wear performance when heated, but the drop varies wildly from oil to oil. Some drop 5-10% while others have a significant drop 25-30%, this is another important thing to consider when choosing your oil. With that said, were right back to the big question; where can we find information on thermal stability? The internet? The pathetic self-proclaimed oil expert? Where? This information can be found on the oil test site along with the anti-wear performance. Before you ask why thermal stability is important, go to the test site and see for yourself. It’s too complex for me to articulate on a forum. The mechanical engineer has a questions and answer section where you can ask questions, and get a qualified answer from a qualified person.
Credit: Mechanical Engineer Rat 540
https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
Sent from my XT1650 using Tapatalk
