Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
Burla
2010 Hemi Reg Cab 4x4
Corey had a great point, maybe it is the 20 weight oil Ram has in these machines that is a main factor in the number of Cam swaps that have been needed. That was the reasoning for changing the eco diesel weights, maybe they just aren't admitting as much for the hemi's because of the CAFE ********.
R.L.K.
Bristol , Tn.
Lol
You saved that picture
Ha ha. , I sure did [emoji106] I knew I'd have a reason to use it at some point LOL
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Wet clutch^ ?
Yeah, I put redline in the primary with the clutches as well.
Problem I have since doing this is that when you shift to 4th from 3rd it does not do it then when ypu let the clutch out you over rev.
Its done this 4 times in about 200 miles after making the change and never before.
I dont know I might switch them both out since its only 2 quarts.
Burla
Yeah my motor runs smooth as silk on the 4qts of 10w30 and 3qts 5w30 .
I will probably keep this mix going for some time as I see no reason to change at this point.
At this point when I change out the oil in my Explorer its getting RL 10w30 or 5w40 or a mix of the 2.. lol
Then will change all the fluids out to Redline on it as well.
If you might remember I switched the transmission fluid out on my Harley to Redline, well I am going to switch it back to Harley oil as Its hanging up on shifts from 3rd to fourth and it did not do that before thought that odd.
Contact Dave at redline and ask him about that. Could be like Kyle said, but the one Application most popular with redline oils are Harley's.
Hemi395
Cape Cod MA
I forgot everything he said as soon as I heard ram SRT 10
He's a member on here I believe. I asked him what oil he used to get that kind of mileage out of a Hemi and he said M1.
Reactions: U&A
Burla
Corey I forgot, did you try 10w30 redline?
U&A
2016 3500 SRW
6.4 HEMI
Try shifting it without the clutch like racing a dirtbike. Right in time with letting off the throttle. If it falls right in it with ease may be a clutch issue.
I did this all the time. When don right it doesn’t hurt a thing and is way faster
Rampant
NJ
392 Hemi
Here is the Harley version of this thread... prob find some great info there.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I rode my last bike that way so I will give that a shot ans see.
I have it in my head that the shift fork is sticking and not pulling it into the next gear.. lol
First time I just thought it was me but after the last time and banging the rev limiter and while paying attention I no thats not the case.. lol
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
If i ever get a Harley (rigid frame again.... of course:cool:). I am going to spend the money on a dry clutch system. Love those
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
My first Sporster had soild struts.
This Lowrider handles great so I will leave shocks on it.. :)
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
I was the guy with ape hangers above my head and a tank shifter that had the clutch on the shift lever. Slow Left turns were kinda hilarious to watch
Rampant
NJ
392 Hemi
Just for clarity, you did use RL Shockproof in the primary and not motor oil, correct?
U&A
2016 3500 SRW
6.4 HEMI
Is shockproof needed or is it your preference? I always used 75-110 Amsoil severe gear.
Rampant
NJ
392 Hemi
I was just looking around on that Harley forum and some guys said they just used RL motor oil in all three holes. Other guys said they tried it and had problems. It seems the consensus around there say to run Shockproof if you're going to go with a RL product in the primary.
Ramnewbie
On my 04 heritage the shifter wouldn't return to the centered position by itself when it was good and hot. It wasn't locked up, just wouldn't return on its own. That was with screamin eagle oil. Dropped that oil and put Amsoil 20/50 mc oil in all three holes and never had that problem again. Also used M1 and Castrol and problem never returned.
Sent from my XT1650 using Tapatalk
Ramnewbie
Actually redline has a chain case oil for the primary, shockproof should be transmission oil. Amsoil, M1, and Castrol will work in all three holes. Amsoil has also split it down if you want different weights and you can get actual primary oil and transmission oil. Just my thinking but I wouldn't run redline motor oil in the trans. Or primary, they don't have one oil for all three holes.
