- Nov 15, 2016
- 1,026
- 833
- Location
- Central Virginia
- 2011 1500 Laramie CC
- 5.7L
Some of you guys have followed my recent posts. Two weeks ago got a misfire on #3. Did the simple stuff and changed plugs/swapped coil pack/cleared codes. The misfire came back before I drove 100 yards. Oh $#@
In less than 1000 miles the truck developed a metal on metal tapping and became undrivable.
So here's the good stuff....failed lifter on #3 and resulting damage...pics attached, and check out #1 starting to get in on the action.
No way in hell I was going to replace the cam with stock so went to Moe's and ordered the HPT cam, install kit with new springs and replaced all lifters (non MDS). Also tossed in JBA shorties for good measure. I didn't go LTs due to simplicity and budget (or complete lack thereof). The heads had to come off and it was a good time to ditch the stock manifolds.
This happened at 138k miles. Prior to this I've done all my regular oil changes 5k - 7k intervals, but due to weather most recently had a shop do the change. All my changes were Pennzoil Platinum 5w20 and WIX or Boss filter....never any problems.
Two weeks prior to lifter failure the shop changed my oil with Wild Wolf 5w20 Synthetic....not sure on filter. Trying not to draw conclusions......
Now everything is back together and she's a beast. PUP 5w30 from here on out and it'll be a couple very short OCIs to get rid of any remaining shavings that might be circulating. Also put a strong magnet on the oil filter to help catch anything.
In all, this cost me $3k in parts and $2k in labor. Labor included header install, some extra cleanup/parts, milling the heads, etc. If you ever deal with this, might as well figure on replacing the timing chain, the oil pump and the water pump if not done recently. Plus all the required gaskets and new head bolts. My guy that did all the work is Kevin Simpson in Central Virginia. He is awesome and if you ever need someone in this area I highly recommend him for any performance related work. He's done custom engine builds his entire life.
Any questions just shoot a reply.
