Demon-HeMi
- Dec 30, 2010
- 4,346
- 3,300
- Location
- Houston
- 2003, 2003, 2008, & 2013
- (2) 5.7 HEMI, 3.7, & 3.6
They have them, it’s on my list!
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/272666671247
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
It is a lot of lights, I put mine on a switch, I don’t use them all the time
Love that painted 2 piece bumper.
The tow hooks line up correct with that bumper .
How a pic with the fog lamps lit up too?
SWEET!!!
I like those headlights too. Badass truck
I Love My 2018 RAM 2500HD 4x4 6.4L. USMC (ret)
Guys can you put the chrome outer grill over it ? And are the Led cree it bulb ?
they are bright LEDs ill say that, im not sure what kind of LEDs are inside them because each LED is a sealed unit
Thank you sir! it has been a great truck for me so far, the headlights i think set the truck off, I painted em satin black and then added clear corners to them, then finished them off with smoking the clear corner and the lens over the signal LEDs just enough to make em appear blacked out so when im coming up on your mirror all you see is a black stripe across the front of the truck lolView attachment 128847
Did you make the brackets for the fogs or did they come with the lights?
The LEDs i used are flush mount LEDs so all i had to do was cut the opening for them to fit into that plastic panel and wire them up, was a pretty easy setup
Which leds did you buy?
Damm I was hoping I could put the chrome outer grill back on over it. I have chrome wheels and door handles so I’m not sure if losing that chrome outer piece will throw everything off.
just these cheapo lights
https://www.ebay.com/itm/2X-7-5inch...TV-SUV-JEEP-/192104898926?hash=item2cba58216e
any good vinyl shop could wrap it for you in chrome, and probably not be expensive since the insert will separate from the outer ring which just makes it even easier
