To remove my cats or not
Yeret
The Village Drunk
Under the hood fixing/breaking something.
5.9 Magnum
I'm running a single in/out Cherry Bomb Extreme. They've got this wing plate deal in the chamber and that's pretty much it. Combined with my enlarged y-pipe and 3" tailpipe, I think it sounds great. Very throaty at idle, would sound awesome with a cam and solid lifters. When you're on the throttle, it's definitely loud but once you're up to speed and let off the throttle, it mellows out a lot.
I'm also running a single in/out Magnaflow cat vs the OEM dual in/single out cat. Not sure how much of a difference that would make in sound.
The only problem with the Extreme is longevity. Mine's less than a year old and the inlet area is rusted, cracked and leaking. I stuck some SteelStik stuff around it and it helped for a couple weeks before falling off. A stainless version of this muffler would be sweetness.
Ehh, does anyone here have any recommendations of a muffler with a similar design that uses stainless steel rather than the crappy mild stuff?
N
Neo299
Magnum 5.2
A Mangaflow 3.5 inch circular straight through muffler maybe.
N
Neo299
Magnum 5.2
If I stroke my 318 out to a 392 can I still use a fuel injection set up or do I have to switch to carb.
Orca
