Towing cross country with 3.21 gears
Discussion in 'Towing & Hauling' started by JGBimle, Jan 8, 2017.
  1. JGBimle
    JGBimle Senior Member
    25
    369
    132
    May 5, 2014
    Ram Year:
    Engine:
    Hi all,
    My girlfriend and I are moving to Phoenix AZ from central PA. I have a 5.7 1500 with 3.21 gears, she drives a 2013 Ford Fusion (around 3500lbs). I'm looking for advice and insights on getting a dolly from uhaul and towing her car out.
    First off am I crazy to consider towing her car 2000 miles with these gears? Will it be harmful to my truck?
    If not any tips or advice will be much appreciated.
  2. MADDOG
    MADDOG Super Moderator Staff Member
    7,458
    1,987
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    Couple of questions for ya:
    4x4?
    Std cab, quad cab or crew?
    short bed? long bed?
  3. bhonshell37
    bhonshell37 Senior Member
    44
    629
    134
    Dec 15, 2016
    Ram Year:
    Engine:
    You should also research whether or not the transmission cooler can handle the heat during towing.
    Sent from my SM-T550 using Tapatalk
  4. JGBimle
    25
    369
    132
    May 5, 2014
    Ram Year:
    Engine:
    It's a quad cab, 4x4, 6.4 ft bed. I'm lifted on 37s
  5. 14hemiexpress
    14hemiexpress Senior Member
    3,223
    830
    Mar 30, 2014
    Ram Year:
    2010
    Engine:
    The 37s will be your biggest problem. All I have to say is load up and go. Check you transmission temps fairly often and keep it in tow haul. I'm assuming you have the 8 speed if you have the 3.21 axle. The 8 speed is a great tranmission.
  6. 69GWC
    69GWC Senior Member
    49
    2,642
    1,653
    Oct 1, 2015
    Spring hill, Kansas
    Ram Year:
    2016 Ram Express QC
    Engine:
    5.7 Hemi, 8sp
    Well I was going to say dont worry about it the truck should handle that with no problems.
    But 37" tires could change my answer , like was said I would look at adding a trans cooler if you can to it
    Have to ask how dose it pull those 37s around and does it search for gears at hwy speeds.
  7. JGBimle
    25
    369
    132
    May 5, 2014
    Ram Year:
    Engine:
    Yes I have the 8 speed. I don't notice any issues with the 37s. I've been running them close to 2 years. Not the ideal ratio but I'm planning for a regear eventually.
    Thanks for the input. I have to be honest I'm a little weary about doing it and that's why I'm looking for the advice.
  8. bhonshell37
    44
    629
    134
    Dec 15, 2016
    Ram Year:
    Engine:
    Around 2004 I towed my wife's Neon from Watertown, NY to Washington with my 01 Ram with the 5.9 magnum. All was well but that was my first time towing anything. I forgot to use tow/haul and fouled up the torque converter. Are you using a half tow trailer or full?
  9. JGBimle
    25
    369
    132
    May 5, 2014
    Ram Year:
    Engine:
    I would use the half tow
  10. 69GWC
    69GWC Senior Member
    49
    2,642
    1,653
    Oct 1, 2015
    Spring hill, Kansas
    Ram Year:
    2016 Ram Express QC
    Engine:
    5.7 Hemi, 8sp
    Ha I was worried about going to 35s but after hearing that I might go ahead a get it done then.
    End of may I will be going and getting my daughter and moving her back here pulling a 12' twin axle enclosed trailer 22hrs one way only stopping for fuel I dont feel this truck will have any problems with it.
Share This Page
