Transmission Downshifting 5th to 4th clunk
StansRam
Oregon
6.4L
I have a 2022 2500 6.4, that has a clunk sound when truck is downshifting from 5th to 4th coming to a stop. The dealership has already replaced the throttle body thinking its mechanical because no codes. Picked truck up Saturday, and still doing the same thing, clunk when coming to a stop from 5th to 4th. At times when it clunks, you can actually feel like someone just tapped you from the rear. The mechanic and I are baffled. Is there any suggestions out there, and I can't have the only one this is happening too.
co-pilot
houston,tx
I have heard others on the forum with the same issue and said the fix was to grease the spline of the driveshaft ? .....worth looking in to
If you decide to pull the driveshaft apart to lube it,as Co-pilot has suggested,make sure you mark it,so it goes back together properly clocked,and i'd use a good quality graphite based anti-seaze to lube the splines
StansRam
StansRam
Oregon
6.4L
How does greasing the splines have to do with the clunk only when coming to a stop, and it clunks when downshifting from 5th to 4th? It only does it when going from 5th to 4th.
It's worth trying,as the splines get sticky,and then basically clunk when they do slide.It's a known issue,use the search function,you'll find a few threads on it
joesstripclub
Lees Summit, MO
2021 2500 PW
I noticed my truck does this. I have a theory that it is the torque converter unlocking at the same time as the downshift. I don't really have any way to verify that though. I will try changing the fluid this spring and see if that helps at all.
53Stude
Central California
2007megacab / 2024 crew cab both 6.7L
It’s not for a Ram, but I do know Ford had a similar sounding issue of a clunk noise. The cure was to grease the drive shaft splines. It cured the problem on two of my friends F150 trucks.
They used to put grease nipples on the 2 piece driveshafts so you could grease the splines,but they don't do that anymore
