Transmission flush or change?
Ian_Olivas
San Antonio,Tx
4.7L Magnum
What's the difference between them and what is recommended. Also how often should I change the trans fluid? I have an 02 and don't think it's been changed out
2011 Ram 1500
It should be like every 30 thousand miles.
Trans flush is when they hook it up to a machine and force all the old oil out of the torque convertor and such.
Fluid change is just changing out the oil in the transmission pan.
Bullitt5339
St Pauls, NC
When you change the fluid, you're not really changing the fluid, you're replacing about 1/5th of the transmission fluid at a time.
bulrid8
Doing a flush can break varnish loose in tranny. That can lead to blockage and failure. Better to do fluid change. Wait a few days and do another. Other options is to do a change by pulling cooler line. This will change all fluid at once. Please read up on doing it, so you don't hurt your tranny.
Sent from my VS985 4G using Tapatalk
usaf2006
Augusta, GA
Yeah I don't, and most, won't recommend an actual flush since the chance that more harm than help is pretty high.
CVX20
Ont,Ca.
2019 Classic Express
I was the tranny guy at a GM Dealer for 15 years and believe me tranny flushes destroyed more trannies than they ever helped.
Ian_Olivas
Ian_Olivas
San Antonio,Tx
4.7L Magnum
Yea I have like 200k miles and think it's been changed once... so from others say about a flush I should just do a change to ensure I don't mess the trans up and not clog it? My fluid has a nice pink color to it and don't have any metallic flakes in it at all either
justin13703
MD
I would definitely NOT do a transmission flush on your truck. Just do a fluid and filter change. I believe that the recommended fluid and filter change interval is more like 60k miles or more.
