Hawsr30
2011 Ram 5.7. Was driving down the expressway at 75 mph when I started to feel a vibration in the steering wheel. As I slowed down to pull off the road the movement in the steering wheel became slower with the deceleration of the truck but much worse in that it was jerking the wheel about 2" as I came to a stop. I limped to the next exit, checked the tires for any movement or a flat, nothing. Chalked it up to possibly having a chunk of ice stuck in the wheel. After another 50 miles at highway speeds with no issue, it started again. I pulled off again under some light and cranked the wheels so I could see the suspension. Immediately noticed that my driver side sway bar was broken. In my mind, Bingo. Talked to a friend that said I should still be able to drive it home. Turned around and drove 100 miles home with no issue. Also had no issues for several days thereafter while waiting to get it in for repair.
Got the sway bar and links replaced and had them check the rest of the suspension parts. No issues. Picked it up and drove it for three days with no problems. 4th day after about ten miles on the road, started again. Pulled over, took off again and it worked itself out again after a couple miles but then returned about five miles later. Took it back in to the shop but of course they haven't been able to duplicate it and can't find any problems with the suspension. I had tires replaced about three months ago but haven't any issues up to this point.
Any input would be appreciated.
