Truck leaning after 2/4 drop
Mike Timmons
Louisiana
Hi guys. I'm new to this forum so if I'm doing anything wrong on here let me know please. So I have a 17 Ram Sport that I just installed the Beltech 2/4 with the Street Performance shocks. The rear passenger side sits up a 1/2" higher than the driver side. Doesn't sound like a lot but it's noticeable. Has anyone else had this problem? Last year I put 2" rear leveling springs on which is when the problem started. Thought it may go away with the new set-up but it didn't. Any help would be much appreciated as it is bugging me.
abouttobeglue
I got the same issue, had it when I did the mcgaughy 44055 2 inch rear drop, got it with the belltech 2/4.
hdoggie24
Huntington Beach CA
I would assume its because the gas tank on the driver side. Mine also sits a little lower on the rear driver side. I thought about trimming the springs just a hair to level mine out.
Midnight Storm
One Badass Ram
Victoria, B.C Canada
4x4 or 2wd? Just curious. I’d like to see pics too if you’re down for that.
BrBlack
Calgary Alberta
My 4x4 measured the same 1/2" difference when i installed my 2/3 GF kit years back.
Dave Robertson
Haysville,Kansas
I too have the 1/2" difference. I used the cheaper 2" drop springsoff of Amazo. Mine only shows with more than a half tank of gas. I've put over 4k on it and no problems, so I'm not going to worry about it.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Pretty common so get out the angle grinder, add some weight, or shim the low side!
Trey J
Virginia
How do you guys like the lowered look? I am thinking about dropping mine and adding the front skid plate. Photos are my Ramtastic and the red truck displays the skip plate I would install. Thoughts???imagejpeg_11.jpg fa262d232ae38f3278649e7bf6410e73 plate.jpg imagejpeg_11.jpg fa262d232ae38f3278649e7bf6410e73 plate.jpg
Trey J
Virginia
I'm not sure why it keeps adding double photos on me.
H1Chester
