Noahryan24
So I have a 16 Ram 1500 with a 4” RC Suspension lift and 35X12.50R20LT tires. Since getting the lift I have had nothing but alignment issues (always the toe). I have taken it back to the place that did the lift and I have taken to to Dodge many times over the past few months with the same issue. I was told all looks good with the lift and suspension system. I went ahead and upgraded the inner and outer tie rod ends and upper and lower control arms hoping that would help and it has not. My truck will not go a day without getting out of alignment after being done. I’m hoping someone here has some advice or knowledge on this because I’m just lost at this point. Thank you in advance!
