dapepper9
- Feb 7, 2013
- 5,908
- 2,224
- Location
- Iowa/Nebraska Border
- 2001
- 5.9L V8
Front PS turn signal went out last night. Noticed the 2x speed flasher on the cluster. Figured bad bulb or corrosion in socket. Checked both and nothing. E-flasher on PS doesn't blink, turn signal doesn't blink but marker light works. Headlights work, taillights work. Rear turn signals both work. Grounds are good. Socket is good. Everything works except the PS front turn signal and the cluster flashes quickly.
Thinking multifunction switch isn't working correctly. Anything else to check before I replace it? Gonna take another look at it tomorrow before doing anything but multifunction switch looks like the most obvious right now.
