UGH, ICE SCREWED UP MY WINDOW QUESTION?
88ROOK
illinois
anyone ever have there window freeze, then try to use but it doesnt budge. well then i go out and the window is halfway down today and when i toggle up, the window goes up to the top then pops back down. i roll it down but its still sticking about an inch up. think the motor is screwed or jumped a gear not sure whats goin here....any thoughts
SOKY_RAM
Bowling Green, KY
it sounds like something I did once. The window actually has some clips that snap on to a hole in the glass. Hopefully you just pulled the clip out. If so you just remove door panel and snap back on.
This video may help
Noneck
2013 Ram 2500 Laramie. 35's 2 inch level. Raceme. Fully deleted 5 inch FlowPro Exh
Try recalibrating your window first.
Sent from my SM-G965U using Tapatalk
88ROOK
88ROOK
illinois
I'll try this but my window would close, go all the way to the top, stop, then kick itself back down about 6-8 inches
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
With a 2018 I would assume it might be covered by warranty if the reset does not work ???
88ROOK
88ROOK
illinois
yea i get that, but just something to get me by now before i take it in. little cold out(below freezing) if the window keeps popping back down
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
SO far the issues I have with my windows is freezing closed :O Hope that reset works for you, It is a pain to go to dealer for a fix, and better if you do not have to ! Please update what you do to fix it
Thanks
WY-Dave
Cheyenne, WY
6.7 CTD
If it is the clip, the answer is NOPE. I tried on my Jeep when the same thing happened and it was the clip.
RoadRamblerNJ
Knoxville, TN
392 Hemi
I didn't have heat for 2 years in my '68 Pontiac Catolina. Young and stupid I guess. Or broke. I seem to remember being broke for more than a few years.
RAMVT
Vermont
I had this issue on my 2016. After the clips popped out the first time it made it a lot easier for it to happen again any time there was a little bit of ice on the window.. I think it took me 3 times of this happening before I started carrying an old debit card to free the window from the window seal.
My tip is to slightly pull up on the window switch without activating the auto up feature. Slowly tap it up until the window seals and then stop. It will keep your window up and wont automatically go back down. This way you can still use your window until you have time to re attach the clips or take it to the dealer.
Greenham
Raleigh NC
The key is to HOLD the button up for an additional 5 seconds before holding it down for 5 seconds after the window is fully down.
88ROOK
88ROOK
illinois
so i did get the window to reset BUT i can tell one of the clips must be broke cause i can grab the window and pull the back side(towads the rear) up and out a little , where as the front seem to be locked back down cause it wont pull up. checked the passenger side and its locked it pretty good and wont move. so see if my guy doing my headers tomorrow will do some warranty work as well
88ROOK
88ROOK
illinois
well finally got window into the dealer, at first they didnt want cover it under warranty, saying i knew the window was froze and hit the button anyway....BS come back in an hour cause the techs went to lunch, come back talk to another guy says dont worry about it ( i'm friends with the GM) and the other service guy didnt know who i was. he said even though FCA wont cover things under warranty the dealership can still cover it.
Addicted2fishing
Durham region
HEMI 5.7
Hold the window button up for 30 seconds. It’ll reset
Tiped on ifone using Tapatalk and auto correct. Can’t you tell?
