The rear will do more than the front. The front hellwig is not much bigger than stock.
It is not the size that matters in this case, and this case only!
The most dramatic difference between the factory and the Hellwig bar is the stiffness of the steel. Hellwig = 4140 chromoly, vs. factory = steel tubing.
Read this thread, I did more or less a side by side (to the extent that is possible with one truck, lol) comparison and the Hellwig is very worthy upgrade!
http://www.ramforum.com/f39/hellwig_front_sway_bar_review_-_worth_not-70367/
Edit: If you only add one in the rear and not the front or vise versa, you might feel a lopsided effect when cornering fast... Due to end link issues, I am currently running factory sway bar in front and Hellwig in rear. When I corner I have this feeling that my front is dipping and spongy on the outside corner, but my rear is still planted solid. Sorry it's hard to explain...
Thats about the only thing good in cali is the roads...lol
Yeah.... no
For somewhere that almost never gets inclement weather, our roads are terrible.
Yeah.... no
Can the Hellwig bars be installed on a truck at stock height? The description makes it seems like you need a 2"-4" lift for them to work.
and here i thought my OEM ram
rides like a cadillac vs any other truck ive ever been in
not really sure going fast around corners....... in a truck, is really all that enjoyable, there are better faster and more fun toys to do that with.
so, since i have a 4x4, i cant upgrade the front? I see nothing for 4x4's.....
If i do the rear, than the front will remain stock and i'll more than likely notice an un-even ride ( squishy front and stiffer rear ) when i take spirited turns or carry a load in the bed?
does anybody make a sway bar for the front 4x4's? If not, why?
ADDCO makes a front upgrade for the 4wd front sway bar; it's on backorder until October though, I've been waiting 2 months for it already, after talking to them they only do one run of the 1500 fronts every year since it's not a great seller.
The front bar is quite stout as it is so it's not as noticeable like the 2wds and a lot of 4wd people want the ability to flex which you can't do with a sway bar, but that's why there are sway bar disconnects.
