txbass06
Getting ready to replace my water pump and add an e-fan tomorrow and just wanted to make sure I thought of everything I'll need or something else I should replace since I'm doing this
I've got the pump, new hoses and clamps,new belt, coolant and flush, 180 thermostat, all fel-pro gaskets, e-fan and...?
One question I did have was about the temp sender for the new fan. I'm doing it right and not just wiring it to a switch lol. There's two different styles of controls. A probe that you stick between the fins of the radiator, and an actual temperature sending unit.
I'm thinking of going with the first since it'll be easier to wire up and I won't have to drill and tap, or wait for a splice for the hose for the other sender.
Sent from my iPhone 4 using Tapatalk
