weird vapor in cab
Austin On The Coast
Oregon Coast
v8 5.9
Just noticed the other day and just a day ago. That some vapor like stuff was coming out of my middle vents on the top of the dash bezel area, idk what from. Thought something was burning June but can't figure it out, and on top of that oddness I think my belts going out
Johnn123
Ontario
That happened in my dakota, turned into heater core going out. Got any oily film on the windshield?
Austin On The Coast
Austin On The Coast
Oregon Coast
v8 5.9
No, its been à little ******** lately lol but other then that, i saw à thread about the Sand thing but it had just Barely done it when i wasnt using my heater
cd36
5.7l Hemi
Does it smell really bad in the cab? Often a leaking heater core will really stink.
Sent from my HTC One using Tapatalk
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
Definately sounds like heater core has a leak. Once had a mustang with all those symtoms and a definate coolant smell. It was an expensive repair labor wise because most of the dash had to come out just to access the heater core box.
DavidRam
SoCal - Redondo Beach
2012 RCSB
No smell? Well then it definitely isn't from last nights dinner. Does sound like something is toasting, though...
Johnn123
Ontario
Sounds to me like the heater core is on its way out, just not there yet. Def keep an eye out for an oily film on the windshield and the smell of antifreeze in the cab.
Austin On The Coast
Austin On The Coast
Oregon Coast
v8 5.9
The ac core was changer before i got it i believe, says ac compressor or something but I def will i was just l'île Wtf is that coming from stopped and decided not to go cruise cause i thought maybe something was on fire but nothing has happened, def keeping an eye on everything lol
Austin On The Coast
Austin On The Coast
Oregon Coast
v8 5.9
Has Only done this a time Or two more sometimes When i get in My Truck it sounds like a pools mixing up
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
If I were you I'd pull my dash, replace the heater core and ac evaporator (core), and dash cap if you need one. And check all the vacuum lines for the doors. And if you want to be like me use it as a chance to really clean the truck.
Trust me though if you go in and only replace one you will be cussing yourself if you ever need to do pull the dash again.
