What caused this damage
Discussion in '5.9 Common Rail' started by dmuney, Mar 2, 2016.
  1. dmuney
    dmuney Member
    37
    38
    Mar 2, 2016
    Ram Year:
    2005
    Engine:
    5.9L HO Cummins
    Would a weak cylinder that may consume oil plug an injector with carbon?
    Sent by me
  2. dmuney
    dmuney Member
    37
    38
    Mar 2, 2016
    Ram Year:
    2005
    Engine:
    5.9L HO Cummins
    Shoulder ?
  3. dmuney
    dmuney Member
    37
    38
    Mar 2, 2016
    Ram Year:
    2005
    Engine:
    5.9L HO Cummins
    My truck is stock I think I have egt and boost guage no tuner no injector tips truck appears stock but I only purchased it 3 months ago with 123000 miles
  4. R/T_Fire
    R/T_Fire Senior Member
    36
    3,396
    1,155
    Feb 3, 2015
    Pleasant Grove
    Ram Year:
    Engine:
    All of that damage can still happen stock. Dirty fuel or fowled injectors will discuss it. Let me fire up the old computer and pull the manual off it and I'll email it to you...
    dmuney likes this.
  5. dmuney
    dmuney Member
    37
    38
    Mar 2, 2016
    Ram Year:
    2005
    Engine:
    5.9L HO Cummins
    Thank you so much. Another question but I think I know the answer so after I did the bandaid I put a new injector in #1 after about 1500 miles I had to replace #1 again. And my dumb luck it seems it's time for another injector but I haven't looked at it yet I gonna take a shot in the dark and say it's #1 again. Could low compression damage a injector or ( my stupid luck ) does it need a transfer tube except the original transfer tube is in the trash so that couldn't be it or because factory lift pump and filter are still messing things up. Getting ready to buy a FASS just haven't ordered it yet
    And thank you for helping me out with the Manuel I'm sure it will be a huge help
  6. dmuney
    dmuney Member
    37
    38
    Mar 2, 2016
    Ram Year:
    2005
    Engine:
    5.9L HO Cummins
    Can someone with a straight pipe on their Common rail take a video of there truck driving with the windows down at WOT I am only after the sound of the exhaust don't worry about what shows on the screen. And maybe a video with it idling also. Thanks everybody for all the help
    05 2500 4dr shortbed 4" lift on 35's, 4" straight pipe, Afe intake
  7. R/T_Fire
    36
    3,396
    1,155
    Feb 3, 2015
    Pleasant Grove
    Ram Year:
    Engine:
    The manual is a huge help and education into the systems on the cummins.
    I'm not 100% sure on a poor cylinder would burn up an injector. It would give poor combustion and should puke out black smoke. You may have an issue with the injector harness may have a nick in the wire poor connection somewhere causin the solenoid to fail. There is a test with a ohm meter to detect if all are working right and it's a ecm issue.
    I pulled my hair out with injector issues before I figured out the issue. Went through 2 harnesses and 2 sets of injectors and 3 extra. Turned out it was the fowled fuel system causing the injectors to fail. Probably not the same issue your having but sounds similar
    Once I get in from working in the shop, I'll look for the manual and send it over
    dmuney likes this.
  8. dmuney
    dmuney Member
    37
    38
    Mar 2, 2016
    Ram Year:
    2005
    Engine:
    5.9L HO Cummins
    I thought maybe fuel system as well buying a Fass 150 titanium today and getting new fuel transfer tubes might as well get the fuel system taken care of and new injectors before I rebuild the motor.
  9. Broncoboy
    Broncoboy Junior Member
    Apr 2, 2016
    Ram Year:
    Engine:
    5.9 cummins
    CD manual
    I just purchased an 07 3500 would love a copy of manual if you would my email is [email protected] thank you
  10. Broncoboy
    Apr 2, 2016
    Ram Year:
    Engine:
    5.9 cummins
    Could I possibly get a copy of that manual I just purchased an 07 3500 am new to cummins could definitely use the guidance thanks
Share This Page
