What do I do with my spare now that I'm lifted?
Solid State
2011 Bighorn
Hey guys, now that I cant use the lil 17" spare, what do I do with it? Will a tire shop or dealership give me anything for it? What did you do? And, what did you do with the empty space if anything?
BogsRam14
NJ
See how far it will roll down the street. But really I have no idea besides either hold on to it or pawn it off on someone who may want it.
dhows31
Mississippi
Speaking of this does anybody know of you could fit a 35" tire or something comparable diameter wise just to get to a shop
H3MI UP
Southeast ga
Mine still under the truck but I need to take it out now that it's useless
xrsman
Ontario
3.0 Ecodiesel
Yes you can fit a 35" under there
Sent from my SM-G930W8 using Tapatalk
Marciel
My 35" spare rides in the bed because it wont clear my exhaust, some times I just take it out. I always pack a plug kit and a compressor though.
Sent from my SM-N910V using Tapatalk
DailyRam
North Carolina
What is the largest Tire that will fit between the factory duals? I am thinking of going with a larger Tire on the stock spare, but if it doesn't make sense then it isn't worth it.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
A small spare is better then no spare, would be no different then some of those little spacer saver tires cars come with.
S
Solid State
2011 Bighorn
I keep a 35" tire in the bed most the time in case of an emergency. Has anybody used the spare after you've lifted? I guess I didnt think you'd be able to
Burla
2010 Hemi Reg Cab 4x4
or tow hitch relocator.
Pcart23
Prarieville, Louisiana
Why not just keep it? It'll at least get you off the road and to a tire shop to fix the flat or blowout
H3MI UP
Southeast ga
I just bought a plug kit and compressor for this same reason.
chopperman1
2018 Rebel
5.7L HEMI
Not sure why you are not simply keeping it for emergencies? I wouldn't use it in 4wd, but 2wd should be just fine. Plug kits and pumps are fine IF it's a repairable tread puncture but wouldn't do anything for you if it's sidewall damage from a pothole, curb or even something you hit on the road.
DailyRam
North Carolina
For those lifted guys on big tires, make sure you have a large enough jack, or it's all for naught.
Ferro
I carry a plug kit. And I have a onboard air system that I can fill my tires no problem. And it runs my train horns.
Sandbox
Warrenton, VA
6.4 HEMI
While a plug kit and a compressor are great ideas, they won;'t fix a sidewall or a tire coming off the rim. Years ago on my '78 GMC Jimmy, I ran 35s with a stock sized spare. It saved my butt a few times!!
Lowrider357
