what does it take
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
If you want a fan controller... This one cant be beat! It's actually made for the 3.8L ford Taurus 2 speed fans! His name is Brian Baskins and he actually makes them out of his garage. Not great on communication, and it usually takes about a month to get the controller, cause he's behind on orders. But it's worth it!
Fan Control
OklaHemi
OklaHemi
new age hemi
cool thanks trup. i wanna get some measurements on something before i settle on a taurus fan. the controller should still work if i use a different fan though right?
Trupiano
Registered User
6.7L CTD
Yeah. I'd go with a cheaper one though. Most fan's you'll find are only one speed. The 3.8L Ford Taurus fan is 2 speed. So this controller is made to handle a low and high speed. Most fans like the flexalite fan only put out 3300 CFM. I believe the taurus fan puts out like 3500 CFM on low and 4500-5000 CFM on high. Just food for thought. And you can pick and pull them for like $15-25 bucks.
OklaHemi
OklaHemi
new age hemi
oh well i was looking in the tahoe while changing the oil and it has an e-fan a dual e-fan. i dont know if it will even fit but i wanted to measure it for ***** and giggles.
Trupiano
Registered User
6.7L CTD
Just make sure the fan is a puller... not a pusher. I mean when you mount it on the back side of the radiator, make sure it's a fan that pulls the air through the radiator and pushes it onto the engine. My first taurus E-fan didn't work this way, it pushed the air through the radiator and out the front of the truck. So when I was driving down the road, it would fight the natural flow of air through my radiator and blow the fuse. Lol I wasn't smart enough to realize that this wasn't a good thing. So yeah, just learn from my mistakes.
OklaHemi
OklaHemi
new age hemi
i try not to repeat bad history so i will look into that thanks for the heads up
HKkid
Missouri
i almost put dont say this in the start of the thread because i knew someone would do it.
Haha I guess I jsut had to be that guy. You can do it on gas, we all know that, and I'm sure you will get there.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Copy Freds truck and hope for the best. Not all the trucks act the same to the mods. On your 15.5 what all is curently done to it? On my regrind cam I was at 15 flat at 90mph which is ********.... hope the new one is faster but aint holding my breath.
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
here's a whacked out thought, Has anybody thought about injecting pure o2 into the intake, via canister with a switch??Hit it just like nitrous, but with o2 instead. HMMMMM?
OklaHemi
OklaHemi
new age hemi
freds truck is amazing i like watching the videos he has put out. currently i have an airraid intake, power wire, at3030 muffler dumped - no cats, and a premium tune with a hyperpac. i saw that i could adjust the rev limeter last night should i?
OklaHemi
OklaHemi
new age hemi
all righ ill be in the truck in a feww ill see what happens
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Stock cam wont be making power at that rpm but you will have great shift recovery. Whats the safe rpm to spin the stock springs for an extended amount of time?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Early build 04's have also reported breaking valve springs along with the 03's. I had mine set at 6500 and shift points of 6200 on stock springs. Good luck...
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Thats what im questioning... all ya will get is shift recovery... change to 6.1 springs and then I would say go for it.
Gary's Hemi
Walker, La
I ran high rpms w/ stock cam for years & I have an early 04. You will be fine. You will be faster w/ the shifts & revs maxed out period!
truckin151
2013 sport
Stock cam and intake falls on its face after around 5800rpms or so. With that said I got the best results when I was shifting at 6100 & 6000rpms with headers.
Redtruck-VA
Virginia
Rocket, I'm starting to understand why you're called Rocket. Piping O2 shouldn't be a lot different than NO2. A regulator would be necessary and some expermenting. Go get Grandpa's oxygen bottle and see how it goes. Wear gloves so if it doesn't work out as planned you can still type.
