What is this breathing sound coming from the engine bay
badblackram06
MS
Have you made sure the back of the intake box is hooked up correctly to the throttle body? There will be a rubber tube connecting both.
Sent from my HTC One using Tapatalk
handcraftedrock
Alberta, Canada
3.7 v6
Does it change when you turn the wheels?
From your video, it sounds like power steering system that is low on fluid or has air in it.
NYCruiser
Yonkers, NY
Vaccum leak? Sounds like a sucking noise to me on the vid.
handcraftedrock
Alberta, Canada
3.7 v6
What I would do is remove the accessory belt. That is great for troubleshooting. Just don't run the engine for too long since you'll have no water pump and alternator.
emjohn4
Your power steering pump is about to take a dump.
However - in regards to the whistling noise - I'd bet you have a missing vacuum line or leak in the intake manifold / intake system somewhere.
handcraftedrock
Alberta, Canada
3.7 v6
I actually topped off the pump after I shot this, it wasnt the problem..
Even with liquid topped, it is possible that P/S system has air in it.
Try to remove the air using hand vacuum pump. Let me know it you need help with it.
Parts rotated by the belt make too much noise. Like I mentioned earlier, remove the accessory belt. Start the engine and listen. It is much easier to find the source of noise.
NYCruiser
Yonkers, NY
Spray something flammable like starter fluid around the plenum gasket and vac lines to see if you can get the engine to race a little. That could disclose a leak source too.
Edit: Carefully! LOL Just need tiny short squirts.
Explit Player
Explit Player
Bristol, TN
Ok guys, the problem was that the alternator was bad. A bearing was the problem like a few people had told me. Much, much better sound levels. I might post a vid on the difference from it.
Sent from my SM-N900V using Tapatalk
