Whats biggest thing you've towed with your 1500?
12gram
Burleson Texas
towed a 2011 23 foot malibu wakesetter wakeboard boat with my ram and it towed it absolutly beautiful haha
deuceram
south jersey
4.7 v8
no trailer due to having a roll pan and no hitch=/ but ive hauled truck loads of ep henry landscaping block in the bed!
paulycoppola5
Schenectady, NY
versa lok!! pulled some of that around in the dump trailer and may grab my buddys mini-ex as well, used to pull that around with the duramax like it was a toy. pretty sure its a 11,000 pound machine...
Gotta finish this retaining wall for my friend soon, getting cold up here! hard to do with regular work occupying 55+ hours a week right now.
Bigboytoys
Bamberg, Germany
2004 QC 5spd
4.7L
Here is mine....
also had 10x25lb bags of cement in the bed and 2 extra buckets on the trailer.
Bigboytoys
Bamberg, Germany
2004 QC 5spd
4.7L
They best part is that they only charged me 60 euros to rent it for the entire weekend. Truck pulled it with no problems whatsoever, and that was on a bad clutch too. Of course the pilot bearing exploded the following Monday on my way into work...LOL!
TXSport
I pull my Kubota L5450 on a 20ft pipetop trailer. Does the job just fine.
DepsilonD
Huntington Beach, CA
Did my first tow with my 1500 Express this weekend. Towed a 1956 Plymouth Savoy parts car from Tucson AZ to Buena Park CA. Prior to the tow, I had set the truck up with the factory brake controller, a class IV hitch, and Air Lift 1000 bags. I was absolutely amazed with how well the truck pulled.
Cormier3288
Upstate NY
2011 Outdoorsman
5.7-liter HEMI
Im planing on buying a 7x15 V-Nose Cargo Trailer this week. I have a 1500 Regular Cab Outdoorsman 4x4.
Im moving from MD to TX next month and will be putting about 2000lbs in it.
How do you guys think it will pull? I also plan to pull 2 quads around once in a while, and 2 HD once in a while.
Do you think that is Too much Trailer for my Truck?
From what i can read i probly should get bags, but the trailer is draining the savings.
Gymkata
I haven't done much towing overall. I mostly use and abuse the bed. In 2007 I did tow a Uhaul trailer with about 6k in it (7.5k total?) from Nashville to Baltimore in my lifted 1997 Ram 1500 4x4. That was a long trip, especially because I was seriously sleep deprived before I even started.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
That will pull just fine I have pulled 24 footer, multiple 22's and 29' camper with mine no problem. It will squat though so make sure you have a hitch that is straight or very little drop so when you are fully loaded chains don't have to be so tight.
Cormier3288
Upstate NY
2011 Outdoorsman
5.7-liter HEMI
Ok Thank you.
Do you think ill need anything like: the shocker hitch, or sway control hitch?
NJDodger
Armpit, NJ
I've moved my XJ around a few times. The Ram tows it with no problem even in the mountains by our place in NY. Will cruise comfortably at 65mph to 70mph and accelerates and passes with no issues either.
audio1der
Airdrie, Alberta
Ok Thank you.
If you don't already have a hitch, getting one which you can add sway control later if desired would be very wise, as to future-proof yourself for anything you may want to tow someday...
CAP LOCK KID
Ontario
2013 Sport QC 4x4
5.7L HEMI
First day I had the '13, pulled a Tow behind Boom Lift (4800#) to a job site.
Took it easy and could barely tell it was there.
Only way i knew was the banging of the pintel hitch.
ajent
Had to pay cash for the trailer to stay in for work. Then got fired the same week. Ha
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Weight distribution hitch is my next buy so I can level out big loads.
$miley
