Wheel Hub interchangeability
RustyRamFan
Knox Indiana
Will any 5-lug first gen wheel hub fit on any first gen trucks?
Is the only option for wheel hubs to buy them used, in junkyards?
I have a 1991 W150 Dodge ram, with a spun bearing.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
have you tried rockauto.com? they have a pretty good variety of stuff for old cars. other than that, yes, salvage yard.
crazzywolfie
under the truck
can't you just replace the race? usually new bearings come with a brand new race. hammer out the old one and install new one
PaPitt
Stephenville TEXAS 76401
5.9L
WELL IF THE BEARING got hot enough to spin .. It most likely stuck to the race & Has spun the race inside his hub. Causing the hub to no longer hold the race tight enough.
... SO HOW RED IS YOUR NECK.
iF YOUR A COUNTRY BOY. & NEED YOUR TRUCK & CAN'T FIND A NEW hub. THEN..
... get a center punch sharpe pointed punch & START PINGING THE RACE LOCATION.
...... meaning ..........
... place the punch on the surface of the hun where the race should rest . Place the center punch against it & hold said punch with Vise grips . & Knock HELL OUT OF IT . PLACING big dibbit in it ... Move punch tip about a 1/4 inch & place another DIBBIT IN THE RACE SEAT BASE .
... then Place dibbits all the way around the race base top & bottom .
..... Now your new race will be tough to drive in place ..
But your a big boy . get after it.
... & Keep an EYE OPEN FOR A GOOD HUB.
your old one may last longer than you expect.
I told you this was RED NECK. REPAIRED . bUT IT'LL GET YOU OFF THE MOUNTAIN.
u2slow
BC, Canada
Cummins 6BTA
81-93 should be the same 5-lug 4x4 front bearing hub.
Joey93
