Wheel Lock Help
Jeremy6612
I lost my wheel lock after all these years. I can't find one that fits and I don't want to force it off. Where can I buy one. I'm running out of places to look. The ones I have bought have been too small to fit around the lug nut.
Burla
2010 Hemi Reg Cab 4x4
You can hammer a 12 point socket on it, you will need a breaker bar instead of impact drill, the impact drill will likely just spin it depending how tight it is. Just try a 26 27 0r 28 mm socket. If it is real tight have a bar you can put over breaker for leverage.
turkeybird56
Central Texas
He's gonna have to either really lube and hammer on a 27, or try a 28 and see if tight enuf, since his measurement in the middle, he may get lucky. There are also (to the OP) all sorts of You tube Vids on how to do this. Locking lugs keep honest PPL honest, LMAO.
cashman070
Victoria, BC
I used a socket as well and hammered it on - then used a breaker bar to get it off - worked very well - looks like your gonna have to get new locking nuts anyway
PoMansRam
East Aurora NY
Looks like a genuine McGard.
I used to work there many years ago. Great company.
Look up their website and see if you can contact someone from customer service. A good pic or two of the lock and they'll be able to set you up with a replacement key.
'06 Ram 2500
Houston, TX
Tighten the other lug nuts slightly to take some pressure off the locking lug then apply the right sized easyout and it should come off easily.
PoMansRam
East Aurora NY
If it's a McGard, the heads are heat treated and very hard. A quality easy out might work, but it's going to take some doing. Probably better off welding a standard lug nut to the face of it.
Joshua Collins
2011 & 2023
6.7 & 5.7
Easiest thing to do would be to go to the closest ram dealer and their service department has a set of all of them. Find the one that fits and remove them. If you want to keep them get the number off it and order a replacement key.
If not go to the parts store and by the hammer on socket and remove them as suggested above.
Dean2
Near Edmonton
If you can't locate a replacement key, any good tire store can spin those off pretty fast. Then just buy a new set. Messing around with home grown solutions isn't worth the time and effort.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Some shops don't mess with it
They will over tighten the locking nut & snap the Lug Stud off
I don't know if it would snap aluminum rims, if conditions were just right
srfotu
Mesa, AZ
I bought a truck with no key and I just found on of those small local tire shops and paid them 50 bucks to get the locks off. I had to try a couple shops cause a few didn’t want to touch it but it didn’t take long to find one that would do it. They jammed a socket on there and broke it loose.
Alan N Stuart
Seattle, WA
6.7L High Output Diesel
This video on YouTube shows how to remove multiple types of wheel locks.
Marshall
Sk, Canada
2014 sport
I may have a spare from my 2010, that was in a wreck I have one for my 2014 Sport 1500 but not home right now, in Canada
Dean2
Near Edmonton
That is good news. Luckily you still had the OEM locks on it.
Cruzrs
3.6 v6
All I have to add would be, after you get a replacement, I used a lenth of solid copper wire and threaded through the lock in the shape of a blanket pin to fasten it to the jack underneath the passenger seat it doesn't go missing
Marshall
Sk, Canada
2014 sport
I run custom wheels and ice tires in the winter , and the wheels come with custom nuts, with a special socket.
Switch to summers in March, In Canada thing you know.
the tire shop guy kept the socket that goes with them, after the switch over.
Went back , and they have new ones in stock , so did not have to hunt throu tool boxes.
