wheel swap
Discussion in 'Tech Info' started by titifly, Feb 18, 2015.
  1. titifly
    titifly Junior Member
    Feb 18, 2015
    Ram Year:
    1993
    Engine:
    5.9 diesel
    What newer style factory wheels are interchangeable with the 8 bolt from a 93 dodge 250? I was told the ford wheels fit,is that true?
  2. crazzywolfie
    crazzywolfie Senior Member
    14,159
    2,154
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    some for rims will fit but i think you might need spacers to run some of the newer style rims just because most of them have almost no back spacing.
  3. cyclepuck
    cyclepuck Senior Member
    41
    266
    84
    Sep 18, 2014
    Ram Year:
    2014 2500 Mega
    Engine:
    Yes the bolt pattern on the 8 lugs are the same from Dodge, GM and Ford. Here's a site that gives more info such as back spacing. http://www.myboltpattern.com/
  4. Redtruck-VA
    Redtruck-VA Senior Member
    5,387
    696
    Virginia
    Ram Year:
    2003 & 1989 D250 RWD
    Engine:
    On the 8 hole rims some 97+ won't fit over the rear axle hub.
    [​IMG]
Share This Page
