Why must the tank be changed?!!!
Cajun337
Louisiana
2019 classic Quad Cab
V6 Pentastar
Brought my 2019 Ram in due to a refueling problem and they’re telling me the tank needs to be changed???? I only have 65k miles on it and it’s pristine. WTH is going on when a fuel tank has to be changed??!! It’s obviously a DEFECT!! Has to be a money trap!! Is there any way I could have prevented this—besides buying a different brand??
TRK_GANG74
Va, Hampton Roads Area
The rollover valve is the problem and it’s built into the top of the tank and can’t be replaced or serviced independently. Just had my tank replaced a few months ago for the same problem. It’s not a money grab. There is an extensive thread on this here. Just search for rollover valve or can’t fill tank and read through it.
DILLIGAF
Canada
Actually you could bypass all that junk, I did it for my flat deck build. ;)
OP go to the Junk yard, Tons of tank.
C
Cajun337
Louisiana
V6 Pentastar
Thank you for the responses. I think I found a replacement with installation at a truck shop for 1/3 the cost.
If RAM has BEEN having this issue I can’t grasp why they haven’t solved the problem, or sent us something telling us how we could prevent the problem. Thanks again.
