Windshield washer not working?
Darkflow
Odessa, TX
As the title says, my windshield washer isn't working. I push the button in to start it and all I get is the wipers going back and forth, but no washer fluid sprays out to clean the windshield.
Anyone else had this problem before? Could it be just the motor used to run this or maybe clogged? It was working maybe back in February. I know for the last maybe 4 weeks it hasn't worked.
Sparkyy
Northern New Jersey
v6
Do you hear the motor working? Maybe you can pop the hood and have someone else push the button in the truck.
I tore mine apart because the sensor was coated and kept saying Low Wash. If you do the same, you can see if the motor or not spins still as water should just pour through it. That or the connection just fell out as remote as that might be.
VB712
Maxi_built
Va Beach
Mine just recently did the same thing. I would push the button and the wipers would move but no spray or even noise from the pump. I replaced the pump with one I bought from ebay and everything works as it should now.
Darkflow
Darkflow
Odessa, TX
I used to be able to hear the motor/pump but these last few days I haven't heard it. I just went ahead and bought a new pump from RockAuto. Hopefully its the problem, which im guessing it might be since I can no longer hear it trying/working.
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Curious... with the season changing did either of you change the washer fluid?
I ask because I have seen it happen one other time to a member that added RainX window washer fluid to his and they stopped working.
Drained that and add the cheap blue stuff back in and they worked!
Just a thought..
Darkflow
Darkflow
Odessa, TX
I think I might have added that RainX. Greenish kind of looking liquid? If i remember correctly. This last time I added a blue one from advanced auto parts thinking it was just low/empty and that's why it wasn't spraying anything.
Darkflow
Darkflow
Odessa, TX
New pump arrived. I haven't installed it yet but last night I washed the truck. So I decided to try the washers again and I think I'm hearing it tryjng/working. I'm hearing a noise, I guess some what like a humming sound when i push the button. Wipers start moving, but no fluid coming out. Could it possibly be clogged up maybe and fluid just isn't being allowed through?
I'm going to work on it Saturday afternoon and hopefully fix it.
Cruizer
Ohio
2010 Sport 4x4 QC
If the pump is running and you're getting nothing, could be clogged or a line off somewhere. Could still be the pump though, even it running it may not be pumping anymore. Keep us updated.
Stealth
South Jersey
Check to make sure your hoses are connected under the hood insulation. Mine recently stopped working and after trying them for a while I lifted the hood and saw fluid coming from above the insulation.
BlkRamRt
SoCal
HEMI 5.7
mine is not working neither. i found out about a month ago. everytime i push it squirts out a little not enough to hit the windshield.
UneasyJmitchell
Louisiana
So we need to avoid adding RainX stuff to the washer fluid? Just plain water or the blue stuff?
JohnD72
Charleston, SC
I've used the RainX washer fluid without any problem. I like the way it works and wouldn't let one possible bad experience scare me away from it.
JJP71584
Pgh, PA
I use rain x all the time...zero issues
Sent from my SPH-L720 using Tapatalk
Havix00
Sacramento, CA
2012 Ram 1500 Laramie
This happened to me a few weeks ago. A nozzle attachment for a hood jet broke and fluid was just drizzling out when I pushed the wash button. I popped the hood, removed the insulation that covered my washer nozzles, and found the problem -- a cracked nozzle base. I just used super glue to fuse the broken pieces together. After a few minutes to let it dry, the fluid line worked and both jets were spraying like new.
I hope this is the problem because it was an easy fix. <10 min job.
Stealth
South Jersey
Both my nozzles broke at the hose above the insulation. I ordered an OEM set from Ebay for $26/pair with shipping. FYI, chargers, 200's and 300's use the same nozzles.
Jim S
Louisiana
5.7 eTorque
How about this problem?
Washer motor worked fine until minor fender bender. I rear ended someone at slow speed.
Tank is full, no problem there, but the motor does not work.
Any ideas?
Jwells
New York
I just went though this last week, I thought the motor had died, we took it out put a new one in it still wouldn't work, took the whole tank out and discovered it a had a black slime plugging the filter and whole
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Have you been running straight water and/or a +32 degree formula? I have found those to not keep the microbial growth down and cause that black sludge.
Jwells
New York
I had actually just bought the truck and went to use the wipers the following say
