wire clips
Discussion in 'Tech Info' started by furydan, Jan 4, 2017.
  1. furydan
    furydan Junior Member
    51
    Oct 26, 2015
    Ram Year:
    1998
    Engine:
    360 magnum
    I am looking for the wire harness retainers that hold the main harness across the top of the firewall.. I bought a 97 ram 1500 and the big wire harness is laying on the back of the motor instead of strapped to the firewall.. they look like zip ties with plugs that fit into the holes punched in the firewall.. Local dodge dealer said they no longer list the part.. "after all..it's 20 years old" he says..
    Any help would be great..
    Dan
  2. SilverStreak88
    SilverStreak88 Senior Member
    3,951
    1,583
    Jul 20, 2015
    Houston, Texas
    Ram Year:
    Engine:
    5.7 Eco Gasser
    Something as such?
    https://lmr.com/item/LRS-N806881S-K/Wiring-Harness-Retainer-Clip-Kit
  3. dudeman2009
    dudeman2009 Senior Member
    22
    1,395
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    The guy you talked to is an idiot. Any retaining clip will work as long as it has the same or larger diameter. The hole size hasn't changed for most retaining clips in 30+ years. They use almost exactly the same thing on every car out there. He just doesn't stock that particular part number, because there are a thousand other part numbers for the exact same thing.
    Autozone, Autovalue, O'reillys, NAPA, all sell them. Hell, i've even seen them at Menards and Home Depot.
  4. furydan
    51
    Oct 26, 2015
    Ram Year:
    1998
    Engine:
    360 magnum
    Thanks for the replies... Ill look at autozone today..
Share This Page
