YOU LOVE OIL WITH HIGH MOLYBDENUM ?Here you go what you think about this oil
SniperDroid
Eaton Township, Ohio
Molybdenum Di-sulfide has been used as a metal to metal dry lubricant for decades. I've even used it in reloading, coating projectiles with it. I moved a .45ACP competition round for Pinshooting from 925 FPS to just over 1100 fps just by coating with Moly. Don't see a problem with it in motor oil. But I prefer Penzoil 0W40.
Burla
2010 Hemi Reg Cab 4x4
Not many companies use mos2 anymore, they now use oil soluble MoDTC which is tri nuclear moly, it is like mos2 on steroids without the downside of having powdered moly in suspension all around your sump and engine. That ppm is similar to moly in race oils, I think it would be a great level to have, not sure I would want to go over 1000 ppm moly, but imo this is all good and clearly that engine likes it.
ramffml
ramforum
Edit:
Looks like you're using the same oil after all, except 0w-20 vs my 0w-30, also my report is a VOA so that might be part of why it's higher.
  • HPL PASS PR PLUS-220928-redacted.pdf
Zoe Saldana
california
6.4l
B
BIG_KAHUNA
america
This oil have ester in it I believe some % I don’t know how much.. seems like a good oil I can get it for under 10 bucks a quart……
