Zone 4" lift with fox shocks not level?
CodyB
Kentucky
Hey All,
I just recently purchased a zone 4" lift with level tail end and fox shocks.. I took it to my local garage to be installed and they called me and asked if I was purposely going for the "carolina squat" :mad:... I drove up there and it definitely isnt any where close to being level in the tailend. I assumed that it would settle and my mechanic said the front would not but the back will because its just bushings so it will just squat even worse with time? I assumed with Zone being owned by BDS, I wouldnt run in to a issue like this.. any recommendations or ideas?
DILLIGAF
Canada
Get better spring in the rear, or spring spacer
danielmid
Southeast WI
2015 Sport 4x4
That front looks like more than 4"? Did your mechanic measure the front to make sure it isn't the front that's wrong?
DILLIGAF
Canada
Thats how they looked maxed out. Mine looked the same with my 6112s until I dropped them a bit.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Hey All,
Thank you for your time!View attachment 509029
Well for starters Zone does not offer a tail high option with any of their 4" lifts that is only 6"
With it being that far off there is a larger issue. What is the part # of the rear box kit zone sent you?
crazykid1994
Do you have leveling struts up front? If so they need to be set down to 0 lift. Your last post on march 2020 states you have bilstein 5100 installed.
CodyB
CodyB
Kentucky
58549 ZOND42 Zone 4" Strut Spacer Lift Kit | 13-18 Ram 1500 4WD | 2" Rear Coil Spacer for Level Tail Rear End 2017 Ram 1500 4WD Gas is whats on my receipt
CodyB
CodyB
Kentucky
Do you have leveling struts up front? If so they need to be set down to 0 lift. Your last post on march 20, 2020 states you have bilstein 5100 installed.
they are being replaced with the fox shock upgrade with the Zone Kit.
crazykid1994
The zone kit does not replace the front struts. Only the rear shocks. Do me a favor and go take a look at them or have the shop send you a picture of the front struts.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Who’s the receipt from?
zrock
canada
so you just used a spacer lift on springs that were already bagged out? if so their is your issue
crazykid1994
What height are your front bilstein 5100 set at? 2.1? Or 2.8?
Nick@GotExhaust
Preferred Vendor
SC
You must have your front struts set for leveling previous to the lift. I am willing to bet this is not a Zone issue and its an installer issue. What front struts do you have right now? I see you mention fox shocks but if that is the ones that come with the Zone lift they are only for the rear. They dont offer zone/fox struts.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Custom Offsets*
They did a copy and paste on the description. There are 2 height options for the 6” lift that’s where the description came from.
crazykid1994
He ordered the 4” kit. Not the 6”. I’m still pretty sure he’s running the bilstein 5100 up front anyways which explains the height difference.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Obviously LOL. It all starts when you buy a kit from a wheel place to start the confusion then you bring it to a place that has zero clue. The only logical explanation is that he brought his truck in with a leveling kit and the installer couldn’t take 5 minutes to ask google or call zone. In the instructions it only shows examples of the oem struts so that is the first red flag.
CodyB
CodyB
Kentucky
Sorry I Have been doing a lot of traveling for work. But just wanted to provide a update. It was the adjustable Bilstiens on the front were rusted and locked at the maxed out position. ( two years on the truck and 30k miles on them.). Anyways after putting new front shocks on it it sets level and I’m very happy with it.
Nick@GotExhaust
Preferred Vendor
SC
Thanks for the update and glad to hear you got it figured out.
