My RAM
brianw0048
EcoDiesel
Replaced HL and Grill
What grille is that? Looks good!
9th
9th
Tallahassee, Florida
Latest Update,
The HL suffered condensation.
Resealing using Butyl won't fix the problem.
I end up putting lots of Silica Gel inside, help stop the condensation.
Then I got the time add a DRL Controller.
Features: Flashes the Halo and DRL when pressing on the horn/Dim them when HL on/Sync flashes with signal lights/Delay turn off.
[yt]POhPOH6PQzQ[/yt]
Note that I put back the stock grill which looks better than the Amazon Grill :p
9th
9th
Bedliner lights project using RGB LED with Controller.
Parts added is:
Tow harness Y adapter.
Mercury Tilt Switch for Auto Switch
Assembled RGB LEDs/Connector
Note that I replaced the controller to RC version and much more smaller than the 1st one I post.
Controller can give different "Mode", "Speed", "Brightness" and "Color Choices"
The 1st Controller(IR)(1st Image posted) is with "Music Sync" and lots of different color.
BHpgh
