How to program Auto door locks on your ram
Bourne2Shoot
NC
Instructions
o 1
Enter the driver’s side of the Ram and close all of the doors to program the automatic lock feature. Engage the seatbelt to turn off the warning chime. Push the key into the ignition but do not start the truck.
o 2
Rotate the key from the "Lock" position to the "Run" position and then back to "Lock" without starting the truck. Repeat this procedure four times within 15 seconds. Stop with the key again in the "Lock" position.
o 3
Press the electronic "Lock" button on the driver-side door panel within 30 seconds of the previous step. A chime will indicate that the automatic door locks have been deactivated. Repeat these steps to reactivate the automatic locks, if desired.
o 4
Complete Steps 1 through 3 again to program the automatic unlock feature, pressing "Unlock" during the final step on the door panel instead of "Lock." Repeat the sequence to deactivate this feature.
