Capozzia
- Apr 7, 2023
- 2
- 0
- Location
- United States of America
- 2018
- 6.4 cummins
The other day i changed the oil in the truck. 6.7
I started it and shut it off immediately then tried to start it again no crank and it didn't crank.
The radio goes off and door locks and windows then the radio comes back on door locks and windows start
working.
Battery's are good lights do not go dim when key is turned. This happened before same senecio.
started truck immediately shut it off then tried to restart and same thing happened.
Went to fuse box and I hear one of the relays click and radio comes back on.
I'm going to follow the click but it has to be in the key circuit.
Turn lights on and they are strong even when i turn the key no dimming.
Iv searched here and cant find the same issue.
The battery charger goes to float then i hit the start button and no change.
Has anyone had this issue before i searched the forum but cant find the same issue.
Could it be the security system? Could it be the key switch. Somehow this happened twice and i have got it to start . I crawled under tuck and had my wife come out and shift it thru the gears and it started. I moved the wire on starter and loosened the grounds on frame and tightened back. I'm going to disconnect the batteries and reconnect. This is the first ever truck i have ever financed or bought this new.
I have never had so many issues with any of my trucks. But this truck makes my wife mad.
Anti lock/def system i keep defending the ram 2018 2500 Cummins 6.7 what's wrong. Thank you for your thoughts, Christopher
working.
