Hi everyone, I have an 01 Durango which has the same 5.9 as you Ram guys. I initially found out about the plenum oil leak issue here so I figured I would ask you all your thoughts. Truck has 110k I had a ton of oil consumption before the plenum fix.
After doing the plenum fix from the forums I was still getting ping, figured it was my plugs since they were iradiums and probably too hot. Anyways I was going to clean the top of my pistons using mopar combustion chamber cleaner and change my plugs. Well good thing I decided to inspect before with my boroscope. I saw small pockets of coolant in a few of the pistons. So long story short I got new EQ heads. I couldn't tell how the coolant got past the heads, gasket looked fine and and I didn't see any cracks, figured probably a hairline crack that just started on both sides but again no evidence.
Installed the heads and the whole intake over again. Also redid my plenum and used blue loctite. Ran the car for a short trip (about 5 miles) then decided just to check with the camera again the following day. I had cleaned the top of my pistons perfectly mind you, took a ton of elbow grease. So I check the pistons 8 1 and 7 I see small amounts of oil. Heads are new and the only thing I did was spray a bit of fogging oil before putting in my new plugs (2 secs of spray).
So now I am baffled, I have no clue why I have oil showing up (after a short trip) on my piston tops. Plenum has been fixed. Here r some photos
