Hemi Tick? Audio included
18GSMRam
FL
As the title asks.... Sounds like a marble in a can...
No codes or any other issues at the moment, 41k miles on a 2018
Audio
wgreggking
rural Arizona
2017 4x4 offroad
Sounds metalic.
Can you pinpoint a side, top, or bottom?
My 6.4 had a couple of times it sounded like that, went away, hemis are noisy.
delete working with member pm.
18GSMRam
FL
Sounds metalic.
Def driver side and top at valve cover. I had the truck outside to eliminate any echos in the garage and took a 2" pvc pipe a couple feet long and listened to the valve cover on both sides.... driver's side had the noise.
18GSMRam
FL
Figured I'd add some run time/idle hours to this post since it maybe a contributing factor and the truck has low miles and is supposedly built after FCA changed suppliers for the needle bearings.
755 idle
1521 run
41700 miles on a 2018
