dwade
I've kind of cheated a bit on gear ratios. I've got a 2015 Tradesmen 1500 4x4 with 3.21 gears and the 6 speed transmission and pull a 24' camper with it. Short trips to local campgrounds I don't worry about it but recently added a set of 29" tires to equate 3.55 gears. At 60mph on the speedo I'm running 55mph by the GPS. On the upside my gas mileage per the onboard shows an improvement in mileage when running empty which IMHIO should equal about the same mileage as my stock 31.6" tires and 3.21 gears.
Even the ratio change was not drastic I did notice a big difference in power while pulling my 7000 lb camper. Driving on US70 west of Indy there are some longer hills that I would often drop to 5th gear and now it stayed in 6th gear on almost every hill and at 70mph the RPMs never went over 3 grand.
Not the best way to do things but definitely helped me at a much lesser cost than swapping gears front and back.
