delete bed vs chassis cab
kevin1
Maryland
v10
Hello all,
New here. Currently have a 1997 long bed, extended cab 4x4 with v10. I carry a truck camper and am looking at getting a new truck.
Does anyone know how the delete bed option would compare to getting a chassis cab?
I'm looking at the Laramie, crew cab, dually.
Thanks, Kevin
WoodGuy
St George Utah
The chassis cab has flat frame rails to simplify mounting for utility beds, custom bodies, etc. Different rear diff centerline lengths from the cab are available as well. Bed delete is a reg pu frame truck that the dealer credits you a ridiculously low dollar amount for no bed
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
In addition, I believe you also have more fuel tank options, and PTO prep options with the chassis cab. If either of those matter to you. I'm pretty sure there are many more differences as well. You might want to just build out each on the ramtrucks.com site and see what the differences are for yourself.
You are looking at a Heavy Duty Ram
Chassis Cab, No Upfit
WoodGuy
St George Utah
52 gallons in my case ;)
kevin1
kevin1
Maryland
v10
I came across this, don't know how the CC would ride compared to the PU without bed and adding a flat bed.
Looks like I can still get the same packages and most options.
Chassis Cab
Most chassis cab trucks feature straight frame rails (a standard to accommodate aftermarket product manufacturers and truck/van upfitters)
Frame rails are 37 inches apart from one another
Cab to center of axle (CA) is 60 inches
More leaf springs in rear suspension spring assembly compared to a pickup – 5 to 12 leaf springs and a factory top or bottom overload spring depending on the vehicle make and GVWR
Shorter leaf springs compared to a pickup (shorter springs are stiffer, providing more capacity)
Pickup & Box Delete
Pickups tend to have curved frame rails for increased ride quality and weight distribution
Frame rails are 34 inches apart from one another
Cab to center of axle (CA) is 56 inches
Fewer leaf springs in rear suspension spring assembly compared to a chassis cab – 2 to 4 leaf springs depending on the vehicle make and GVWR
Longer leaf springs compared to a chassis cab (longer springs flex easier, providing for a smoother ride)
WoodGuy
St George Utah
Mine rides very well for a 1 ton truck, but it has a 9' utility body full of tools too ;)
If the truck is going to have a permanent Camper sitting on it
It should ride very well
It could be setup with the largest fuel tank & plenty of storage room
company changed hands, they are now called NIMBL
Best-in-Class Ford F-350 Super Duty 4x4 with 7.3 liter “Godzilla” gas motor, but build our campers on Chevrolet/GMC and (Dodge) RAM 1-ton trucks as well.
