2013 Powerwagon death wobble
Electrichemi
indianapolis
Last couple weeks have been hitting some bumps in the road the truck wants to dart to one side then get a horrendous vibration in the steering wheel enough where I have to pull the truck off the road and slow down would this be the infamous death wobble?
olyelr
Kewadin MI
Yep. Sounds like you are describing death wobble.
ThunderMug95
North Prince George, VA
Did this start after hitting said bumps? You may have bent/broke something. DW can happen under otherwise perfect conditions usually induced by poorly designed/installed suspension components and/or worn out components.
SeppW
Northern VA
Hemi 6.4L
Still running the OE damper? Could be shot.
Juice17
Nj
In the jeeps was usually the trac bar.
soapy
Northwest
6.4 hemi
Check all your front end parts for looseness. A new steering dampener may stop the problem for a while but is only a mask until the worn components are replaced.
Goodie1990
