TimboRam77
- Joined
- Nov 17, 2017
- Posts
- 137
- Reaction score
- 79
- Ram Year
- 2021
- Engine
- 5.7
Update
As reported in this forum the 1500 with acc and lane keep is now fully supported and a harness is available which is plug and play. Actual install and full programming is quick and easy. Panels to remove are very simple if done correctly. However the mount as instructed takes 48 hours to cure. This is day one of installation. Steering disconnects at 32 mph or lower. You need what's called a fork installed to run. Many are available other than from comma.ai. These non standard forks are reported to be much better than stock and will steer to zero mph. There are modes available with the stock fork that I have not figured out yet. Laneless that rides on snow covered roads. Again day 1 for me. Some say mounting angle and height are critical. My mount is not perfect and things seem to work but I'm requested to intervene frequently on back curvy roads, less to very infrequent on interstate. It may still be learning. Initial calibration distance until self driving took less than 1 mile. I plan to attach pictures after this post. There will be haters and lovers of this technology. I'm glad we have the freedom to express our opinions. I hope this helps those considering this product.
