Good aftermarket lug nuts?
Panduh
Saint Augustine, FL
What is a quality aftermarket lug nut for a 2016 1500 with factory alloys? Something simple and solid, and without that horrible thin cover that deforms, spins and rips off! Are the splined lugs better than hex?
Jeepwalker
WI
2012 Reg Cab, 4x4
What's wrong with what you have now? Or are you changing wheels and need lug nuts? You're in FL so you have a lot of options. Are you looking for chrome or black?
For solid, look for some tripple-plated chrome lug nuts. I've seen some on Amazon and Summit which look pretty good (but haven't used personally). The 'good ones' won't be cheap, but worth it if the chrome is super nicely done. But they'll still flake from high torque impact wrenches. After a while at least. Best is to have them hand-removed, which a lot of shops don't want to do ..but some will.
Jeepwalker
WI
2012 Reg Cab, 4x4
Chrysler updated the design like 20 years ago so the stainless steel cap is 'crimped' over a ridge on the lug nut. So they don't fall off. The key is to NOT use an impact wrench on them -- Ever, and the caps won't distort. They'll keep their shape & last and look great a forever (theoretically) if treated 'right'. I put a daub of RTV around the base of mine (at the crimp) to keep moisture out.
Just ask your tire/brake shop to remove/replace the tires with a hand wrench. I noticed quite a few shops around here do that now. Don't let some monkey with a 900# impact wrench murder your lug nuts....
Jeepwalker
WI
2012 Reg Cab, 4x4
Here's a set of new take-off's to consider. Cheaper than aftermarket, and OEM quality. But they are 'caps' it appears ...even though you said "no caps". You can see how they're a lot nicer than in the old days. A lot of guys don't like the 'caps' but they're S/S and really do outlast chrome lug nuts in most cases (if not abused) ..and sometimes outlast by a lot. Just an option to put on your radar screen. If after 10 years they start looking beat-up, just buy another set. Verify/check your thread size, but should fit:
Like I said, put a thin daub of gray RTV around the base before you install and moisture won't get in from the back. Good luck. Let us know what you get :waytogo:
GRKN
Just the thread I needed, several of the lugs on my 09 are getting rough and need replacing. The above link looks like a great price
Daw14
Gorilla lugs are one piece ,as are mcgaurds .the gorillas do surface rust after a short time ,about A year . But do not crumble like stock. Mcgaurd makes the locks the come with the truck , but I got rid of them when I purchased gorillas so I can’t speak to the longevity of them.
gofishn
Iowa
hemi 5.7L, 345 cu in
pretty sure Ford Explorer ST are M14x1.5 and they come with black rims and chrome lugnuts. Coudl try to jump on ST Foruma nd find smoeone local lookign to switch over. I know I got a set of brand spanking nwew chrome ones sitting on my work bench, Have not yet got aroudn to see my 22 Ram has teh junky covers, like my 22014 did, or not.
If so, guess wehere my Ford Chroem ones are oging?
Jeepwalker
WI
2012 Reg Cab, 4x4
..As Jeepwalker said above, those capped nuts are crap. Their caps will eventually come loose, turn on the nut and make it nearly impossible to remove.
Actually I said the opposite, but... LOL. :D
If the caps *don't* get 'stretched' too much they will last the life of yer truck (esp if you apply a daub of RTV at the cap seam). The caps can't fall off like the old Chev and Jeep caps of the 90's cause they're crimped on. Using an impact wrench on them is like banging a hammer on a fender and wondering why there are dents? LOL.
That said, good quality chrome L/N's are nice. And they're even shinier.
With either one, I would still ask shops to hand undo them (and re-tighten). But can you trust a tech to remember?? Stand nearby with a long-reach tazer, perhaps!
John Jensen
San Diego County
Ecodiesel
Jeepwalker,
Sorry for the misquote. Yep, they will last the life of your truck if not removed often and always hand removed and hand tightened.
However, I experienced the caps stretching when torqued and/or over-torqued. If one is going to spend the money on new nuts, I suggest they get solid nuts. Yep, you can't trust anyone but yourself, I think most dealer techs would not hand tighten.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
I got gorillas to replace my stockers when they get worn. However it’s been almost 6 years and I have my wheels off 2 times a year minimum to swap back and forth from winter to summer wheels. I use an impact to take off and a tq wrench to put them on.
indept
South Jersey
If they can't take an impact they're not worth puting on your truck. That's like marketing a frying pan with a non stick coating. The coating will last forever as long as you don't cook anything in it. :deal: :eek:
JW2 Innovations
Preferred Vendor
Olive Branch, MS
2016 Ram 2500
CDJR all have these same junk lug nuts with caps. I always swap with solid ones. Here are the sets I've ordered.
When those caps come off, you lose 1mm in socket size. Doesn't sound like a big deal until you round off the semi rusted nut below on your chrome wheel. Hope you're in the driveway when it happens and you have the right socket to get it off! Been there too many times, now I immediately change each time I buy one of these types of lugs. And ensure I buy solid ones that match my lug wrench size included with the jack.
14mmx1.5 that use same size as oem lug wrench
Those with 1/2-20 needs
Badger 13
North Idaho
2013 Dodge Ram 1500
I didn't have any problems with mine, but changed them out to Mcgard's for piece of mind. Mcgard's are made in the US. I have had them on for about 5 years, and they still look like new. The Gorilla brand is nice, but not made in the US.
Jeepwalker
WI
2012 Reg Cab, 4x4
I like chrome lug nuts too. I have some on various cars. But I'm wondering how the caps come off for you? They're literally 'crimped' over a ridge around the steel lug nut. You're not thinking about the 90's GM/Jeep caps are you?? Those did fall off chronically. The "ridge" (Ram lut nut below) is where I apply RTV to prevent rusting beneath cap:
Like I say, if you don't let tech's "murder" them... :rolleyes:. But the nice thing about chrome is they're even shinier.
Don't use caps or you will collect that ghetto prize for playing that ghetto game, just a matter of time. Not a huge deal even if the cap comes off, but if it happens on the side of the road when you are changing a flat, be prepared. I have taken my gorrilas off many times and they have no rust, but I hear some guys in snow states have some rust? If so use anti sieze and/or hit the lugs with fluid film after they are installed, just shoot into the lugs holes and wipe the rim. Might have to wipe again after a couple trips. If you use anti sieze also torque them a second time just for giiggles after a week.
You can pull my impact wrench for lug nuts out of my cold dead hand. My dewy 20v impact is the best tool over for lugs and has paid for itself many times over, btw I only like about 1/2 the tools on this platform. but my impact is one of them. Don't use an impact on lugs, no thanks, just say'n.
alpinegreenneon
South East Wisconsin
My '95 and '98 Neons have the originals with caps in perfect condition. Same with my two 2016 Darts and 2018 Ram. I use grease on the crimps. I don't own an impact air tool and always use a torque wrench. No one else touches my lugs.
Goodie1990
