I have a 2016 Ram Laramie 4 x 4 3500 HD. The mileage is 38,450. This is a definite Safety Concern. While driving home the other day at freeway speed here in San Diego, there was a vibration in the front and then I felt wheel wobble, luckily I was close to home so I limped off the freeway and to my home. It turned out that 7 of the 8 wheel lugs sheared off at the hub. I did check other forums and it appears that this has occurred not frequently enough to warrant a recall. I have checked and ordered the necessary part replacement and will do the hub replacement.
This might be a good time to start buying lottery tickets, I would be feeling vey lucky, if I were you.
While I sincerely appreciate you reaching out to others to give warning, my mind is usually focused on the 'how could this have happened and were the manufacturer's guidelines followed throughout the life of the vehicle'.
Or, what component failed to cause this outcome. Like a forensic analysis.
While I realize that the pictures posted are not the best source for detailed information and that we can't be certain that any apparent non-linearity in the studs isn't a result of lighting and camera angle, it still makes me wonder.
And, I must add that I am not a mechanical engineer and can't be certain of the failure mode on wheel studs. Maybe, we have an engineer that might provide their 10 cents worth.
Those are my disclaimers.
I did a bit of my own amateur forensics using the posted picture and noticed irregularities and lack of uniformity in several of the studs. A couple of them appear to have been elongated but I don't know if that was a result of the failure mode or the root cause. That determination is beyond my pay scale.
This is one of those studs that makes me wonder.
