Rubelus
Hey guys, looking for some help with a persistent cylinder 7 misfire on my 2012 Ram 1500 4.7L.
It has a P0307 and misses mostly at idle. Once I bring the RPMs above about 1,500, the misfire basically goes away.
So far I’ve replaced:All 8 fuel injectors, all 16 spark plugs and plug wires, cylinder 7 coil, both cylinder 7 lash adjusters/lifters, cylinder 7 rocker arms
Cylinder 7 had about 150 psi dry compression; cylinder 1 had 175 psi. A wet compression test brought cylinder 7 up to about 175 psi. Spraying carb cleaner around the cylinder 7 intake-manifold area made no difference.
When I removed the old #7 rocker, I found the roller badly damaged/scored (photo attached). After replacing it, the misfire got noticeably better, but it is still present.
Does this sound more like a damaged cam lobe, a valve/seat issue, or possibly ring sealing because the wet compression test came up? What should I inspect next before I pull the head?
Thanks.
Thanks.
