BrodyTampa
Hey everyone, love this forum and all the helpful people. This is my first time asking for advice. I apologize for the lengthy post but I’m not sure where to turn next.
2014 Ram 1500 Sport, 5.7 HEMI, approximately 120,000 miles.
I’ve been chasing an intermittent misfire that has progressively gotten worse over the past three weeks. Had a mobile mechanic spend five hours diagnosing it yesterday, but still haven’t identified the cause.
Code History:
Timeline:
October 3: First experienced rough idle and misfires after clearing codes while troubleshooting an EVAP issue. Initially P1417 and P0307. Truck would sometimes run rough, hesitate, or surge slightly, but a restart made it run normally again. Then next start rough again.
Truck sat:
October 16: Replaced all 16 spark plugs with NGK 92145 from RockAuto, torqued to 13ft/lb. Came pre-gapped and same as originals I took out. Truck initially ran smoothly but began misfiring again within minutes. P0300 and P0171 appeared with the check engine light flashing.
Truck sat:
October 25 – Mobile Mechanic Diagnostics:
Mechanic spent approximately five hours investigating.
Additional Information:
Looking for advice:
The biggest clue seems to be that starter fluid temporarily keeps the engine running. I’m wondering about fuel delivery, injector control, PCM, or an electrical/ground issue, or mechanical?
Has anyone experienced similar symptoms on a 5.7 HEMI? What would you test next before replacing expensive components?
I’d appreciate any suggestions!
Code History:
- P1417 – Cylinder 7 reactivation control performance (MDS).
- P0307 – Cylinder 7 misfire.
- P0300 – Random/multiple cylinder misfire.
- P0171 – System too lean (Bank 1).
Timeline:
Truck sat:
Truck sat:
- Scanner showed heavy misfires on nearly every cylinder, with only two cylinders not registering significant misfires.
- Found a broken engine ground strap. Bypassed with jumper cables, no improvement.
- Smoke-tested intake/vacuum system. No obvious leaks found.
- Tested ignition/spark using coils and spark plugs.
- Found some “loose spark plugs” and tightened them. No improvement.
- Investigated exhaust manifold leaks and removed oxygen sensors, but did not restart the engine with sensors removed. Said catalytic converters look ok
- Reported fuel pressure was good, but I don’t have an actual pressure reading.
- Probed PCM connections and reported apparently weak signals to the fuel injectors.
- Mentioned a possible crankshaft keyway/timing issue, but nothing confirmed.
- Sprayed starter fluid into the intake. Engine ran noticeably better and stayed running while spraying, but stalled almost immediately when he stopped.
- Returned Superchips 87-octane tune to factory stock. No improvement.
- Previously replaced ESIM, gas cap, and purge valve while troubleshooting EVAP issues.
- Both exhaust manifolds have broken bolts and have ticked on cold starts for years.
- No noticeable lifter tick.
- Engine oil is Pennzoil Ultra Platinum 5W-20.
- The truck originally had intermittent misfires but could drive normally after restarting. Now it runs extremely rough and frequently stalls.
- ABS module has been broken for a few years
Looking for advice:
