It's easy to add factory fogs, but at this point there is no kit offered by mopar.
I did this on my 15 2500 tradesman. Adding the sales code and switch with fogs is the same as previous years. The problem I found is the fog light jumper is 2 pieces. The piece that goes between the fogs is easily found online. The second, I found out to be tied into the main lighting harness. So you can make your own secondary harness to tie into the tipm or whatever it's called now or tap into the fog light feed with a t tap connector.
Sent from my VS985 4G using Tapatalk
